HP LaserJet 1100 Printer Logo
A
Anonymous Posted on Aug 25, 2012
Hp p1102w offline
Printer erratically goes offline
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 04, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
483
Points
This worked perfectly, I hope it doesn't lose the connection again!
Phil D
www.TheBocX.com
3 Related Answers
Soulvisitor
Soulvisitor
  • 1113 Answers
  • Posted on Oct 19, 2007
SOURCE: HP 1020/1022 PRINTER OFFLINE
No drivers / Incorrect driver setup on user pc
Anonymous
  • 564 Answers
  • Posted on Mar 31, 2009
SOURCE: Printer offline HP 4500 series wireless.
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
Bfsas1
Brett McGuigan
  • 258 Answers
  • Posted on Jan 28, 2010
SOURCE: printer going offline
unplug the printer's usb cable from computer then re-insert, leave printer switched on during process
2answers
How can I fix HP Printer Offline Windows 10?
This video shows you how to fix a printer that is offline:
tip
How to print a configuration page from an HP LaserJet P1102w
The HP LaserJet Professional P1102w is a compact wireless desktop printer. It is very easy to set up and use. Unlike larger HP printers, the P1102w does not even have a true operation panel; it only has a power button, a cancel button, and a wireless button.
However, like just about every other HP printer, the P1102w has the ability to print out a configuration page that displays many of the printer's settings and statistics. This page is called the self test / device configuration page, and on it you can find the printer's page count, number of paper jams (broken down by section), amount of available memory, network settings, and more.
To print the device configuration page, make sure the printer is on and ready. The green light on the top left side of the printer should be lit. If the red light is lit or flashing, then there is a problem with the printer -- such as no toner or a paper jam -- and you won't be able to print the configuration page until the problem is rectified. You'll also need to have at least one sheet of paper loaded into the paper tray. Make sure the two side fences and the rear fence are snug against the paper to prevent misfeeding.
Press and hold the cancel button (the button with the red X on it) for about four seconds. The printer will warm up and begin making noise, and the green light will start to flash -- when these two things happen, you can release the cancel button. The printer will print out the configuration page, face down, and once it has finished the green light will stop flashing and the printer will quiet down.
How can I fix Hp Error 49.4c02?
Strategy for How To Fix HP Printer Offline In Windows 10 and Mac?
First You Must Check Your Basic Connections:
A few times show hp printer offline circumstance when it isn't accurately associated with your framework, or there shows up some organization issue prompting the printing blunder. Audit for the equivalent to measure with the printing capacity.
For what motivation behind why does my hp printer-state offline?
There can be a few reasons for what reason does my hp printer props up offline. One of the principal purposes behind the HP printer demonstrating offline, It might be an issue with your Wifi link or association. You should attempt to get check your Wifi Connection, is it appropriately associated or not.
Purposes for that Why Does My HP Wireless Printer Goes Offline?
HP printers require a strong association and organization with the framework's If your association is lost the availability, It will demonstrate the HP printer to be offline "Use the printer in offline mode" A the client must guarantee this alternative isn't picked on his printer as it would not permit the customer to use the printer with a far off association. The course for remedying this setting is according to the accompanying Select the Start menu-click on settings-Click on gadgets printer and scanners-from the recorded line uncheck the container given before "Use HP Printer Offline." This would restore your hp printer in online mode.
For detailed information on these kinds of issues. You are suggested to visit the link shown below:-
Hp Error 49.4c02
2answers
My computer is not recognizing my 1 year old HP P1102W Printer
up grades of the os (win 7 to win 10 ) will affect the drivers
printer cable not properly connected
check for a change of compatibility between printer and pc
Message says printer is offline
Sounds like your usb connector or cord. When you change the printer to a different usb outlet you may have to go to control panel and select the printer as the default printer. Always use the same plug if it works good.
Reset paper jam error HP P1120w
i have a hp p1102w laser jet, it's about a year old. Hp want 130 replace it, I only paid 100 for it. I have a blinking red light. It tell me paper jam, I can find no Paper that would make the jam. After two day we looked at it again, when we turned it back on it said out of ink. I knew that was no true, because I had just put new ink in it. Now it's back to paper jam. What do I do? Does anyone have any ideas?
k24674
Grand Canyon Tech
Grand Canyon Tech
