20 Most Recent HEWLETT-PACKARD Hewlett Packard P1102 Laser Printer Questions & Answers
Press and hold the red X button (cancel) until the green light starts to blink.
HEWLETT-PACKARD... | Answered on May 05, 2015
Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? What printing problems are you having?
HEWLETT-PACKARD... | Answered on Mar 17, 2015
  • I take it you are refilling the toner cartridge...
  • Switch the printer off.
  • Press and hold the green button on your printer and turn the printer on. You will see that the lights flash for a moment and then turn off. After a few seconds, the attention light will turn on followed by ready light and the green light. Keep pressing the green button. In a few seconds, the attention light and the ready light will turn off.
  • Push the toner rotate button while you continue pressing the green button. As you briefly push the toner button, you will see the light flashing. Release both the toner button and the green button.
  • Repeatedly push the red button (cancel button). Now all the working lights on the printer will turn off.
  • Open and close the lid of HP printer once. The light will start blinking.
  • Press the green button. Your HP toner cartridge chip will be reset.
  • HEWLETT-PACKARD... | Answered on Dec 16, 2014
    Configuration page denotes total gape count..
    Press menu button...scroll to information..enter...scroll to configuration page...enter..
    HEWLETT-PACKARD... | Answered on Sep 23, 2014
    Replace toner cartridge., toner above to empty
    HEWLETT-PACKARD... | Answered on Aug 21, 2014
    power on printer after printer is in ready state press and hold down x
    cancel button until ready flashes then release you will get config page
    HEWLETT-PACKARD... | Answered on Aug 07, 2014
    Here's a solution HP has that explains how to print wirelessly from iPhone for that printer. Review the different options and find the solution that works best for you.
    HP Printers and Supported Mobile Printing Solutions
    I am an HP employee.
    HEWLETT-PACKARD... | Answered on Jun 26, 2014
    At the control panel, press and hold the cancel button until the ready light starts blinking, and
    then release the button.
    HEWLETT-PACKARD... | Answered on Jun 18, 2014
    Only way to replace formatter board..
    HEWLETT-PACKARD... | Answered on May 03, 2014
    it dependes if you have local wifi where your HP printer is connected.
    If yes, you only need to install HP ePrint app.
    After you start the app ignore activate printing via hp cloud, you don't neet it. If you are with your Android on the same WiFi your app will identify the printer on the network and you only need to indicate the photo or file. Open it and print. Tha'ts all.
    HEWLETT-PACKARD... | Answered on Oct 18, 2013
    Tip
    How to print a configuration page from an HP LaserJet P1102w
    The HP LaserJet Professional P1102w is a compact wireless desktop printer. It is very easy to set up and use. Unlike larger HP printers, the P1102w does not even have a true operation panel; it only has a power button, a cancel button, and a wireless button.
    However, like just about every other HP printer, the P1102w has the ability to print out a configuration page that displays many of the printer's settings and statistics. This page is called the self test / device configuration page, and on it you can find the printer's page count, number of paper jams (broken down by section), amount of available memory, network settings, and more.
    To print the device configuration page, make sure the printer is on and ready. The green light on the top left side of the printer should be lit. If the red light is lit or flashing, then there is a problem with the printer -- such as no toner or a paper jam -- and you won't be able to print the configuration page until the problem is rectified. You'll also need to have at least one sheet of paper loaded into the paper tray. Make sure the two side fences and the rear fence are snug against the paper to prevent misfeeding.
    Press and hold the cancel button (the button with the red X on it) for about four seconds. The printer will warm up and begin making noise, and the green light will start to flash -- when these two things happen, you can release the cancel button. The printer will print out the configuration page, face down, and once it has finished the green light will stop flashing and the printer will quiet down.
    on Jun 11, 2011 | HEWLETT-PACKARD Hewlett Packard...
    Try a different outlet and different power cord.
    HEWLETT-PACKARD... | Answered on Sep 26, 2017
    No doubt the feed rollers are worn.
    HEWLETT-PACKARD... | Answered on Sep 22, 2017
    HEWLETT-PACKARD Hewlett Packard P1102 Laser Printer Logo
    Popular Tags
    27 questions posted
    Top HEWLETT-PACKARD Office Equipment & Supplies Experts
    Harrie
    Victorman
    Victorman
    Are you a HEWLETT-PACKARD Office Equipment and Supply Expert? Answer questions, earn points and help others
    View Most Popular
    • HEWLETT-PACKARD Office Equipment & Supplies
    Most Popular Question
    print wirelessly from android phone hp
    • Office Equipment & Supplies
