Computers & Internet Logo
Anonymous Posted on Aug 21, 2012
Ytxsxqew.exe has stopped working
Unbelievably slow to start up then box popped up with above message.
Anonymous
Level 3:
Top Expert:
  • Master 4,961 Answers
  • Posted on Aug 21, 2012
Anonymous
Master
Level 3:
Top Expert:
Answers
4961
Questions
0
Helped
1186536
Points
16069
You have viruses and malware.
Start your PC and press F8 several times until the boot menu comes up. Then select "Safe Mode with Networking". Now get some or ALL of the FREE programs below.
Download, Install and Run Malwarebytes Anti-Malware:
http://majorgeeks.com/download.php?det=5756
When Installing choose the non-pro version.
Download, Unzip, Install and Run TDSSKiller:
http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.html
Download, Install and Run Super Anti-Spyware:
http://majorgeeks.com/SUPERAntiSpyware_d5116.html
If you have an outdated Anti-virus program then Download, Install and Run Avira Anti-Virus:
http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.html
Make sure to select ALL of the "threat categories" when you install or configure Avira...
You should be in pretty good shape if you run and install all of these programs.
Testimonial: "Thanks for that. I already have Avira Premium on board, I think Avira will be annoyed that you suggest I havew viruses etc on my PC. Also have a Firewall. Can the others you suggest be loaded "on top of" Avira? Arnold"
  • 1 more comment
  • Anonymous Aug 21, 2012
    White Zombie
    Thanks for that explanation. I,m somewhat puzzled as I have Firewalls installed as well as Avira Premium.
    You need to try an anti-malware solution to fix your situation like Malwarebytes or Superantispyware. You will find and fix some problems with them.
4helpful
Updater has stopped working ... error message pop up
turn it off in startup .
clik your start run
type msconfig
look in top right for startups
unchek
SoftwareUpdater.exe apply close restart system
Hello, I have Vista and everytime after my computer boots, I get a pop-up that states: KBD EXE is not working. What is this and how do I fix this problem? Thanks, Pat
Assuming that once it starts everything is OK and the computer functions normally, try this:
Right above the start ball, there is a command line. In that white space, type MSCONFIG.
When the window opens, click on the startup tab. Find the KBD.EXE command and uncheck the box next to it. This will tell it not to run.
Now restart the computer. In Vista you'll get a message that a program was blocked. Tell it to run the blocked program. When it opens (the system configuration utility), check the little box that says not to display it again. Now everything should work.
3helpful
123CopyDVD.exe has stopped working......
First, Uninstall your program using Add/Remove Program in Control Panel.
Start Menu -> Control Panel -> Add/Remove Programs
Note: Be aware of shared files don't remove them, it will affect other programs that use that file
After Uninstall, restart your computer
Then start again, proceed to installation of your program.
Have HP mini notebook. everytime im on the
Sounds like spyware / malware i would use an online scanner like Eset or a program like Malwarebytes.
also to stop the computer from restarting open the command prompt window (start menu, click run, type cmd, click ok...) type "shutdown.exe /a" without the "" and there is a space between exe and /a this will abort the shutdown.
17helpful
3answers
Windows cannot find gphone.exe??
Gphone.exe is a file that an instant-message worm infects. This worm spreads through Google chat and Yahoo! Messenger. This “Gphone.exe” worm disables your antivirus security software, and downloads more crapware onto your PC.
To remove do this:
1. Block Gphone.exe sites: http://rnd009.googlepages.com/
2. Stop Gphone.exe processes: %Windir%\gphone.exe
%System%\gphone.exe
%System%\DEFAULT_NOT_SET.exe
C:\Documents and Settings\All Users\Desktop\gphone.exe
%Temp%\gphone.exe
%System%\gphone.exe
%DriveLetter%\New Folder.exe
%DriveLetter%\gphone.exe
[ROOT FOLDER]\New Folder.exe
[ROOT FOLDER]\gphone.exe Get rid of Gphone.exe files:
%DriveLetter%\autorun.inf
%Windir%\Tasks\At1.job
[ROOT FOLDER]\autorun.inf
C:\disk.txt
%System%\autorun.ini
%System%\setting.ini
%Temp%\log_[TIME AND DATE].txt
3. Delete Gphone.exe registry keys using regedit from start - run:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\WorkgroupCrawler\Shares\”shared” = “[ROOT FOLDER]\New Folder.exe”
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run\”Yahoo Messengger” = “%System%\gphone.exe”
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\”Shell” = “Explorer.exe gphone.exe”
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\Schedule\”AtTaskMaxHours” = “0′
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\Schedule\”NextAtJobId” = “2′
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\System\”DisableTaskMgr” = “1′
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\System\”DisableRegistryTools” = “1′
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer\”NofolderOptions” = “1′
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Main\”Default_Page_URL” = “http://rnd009.googlepages.com/google.html”
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Main\”Default_Search_URL” = “http://rnd009.googlepages.com/google.html”
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Main\”Search Page” = “http://rnd009.googlepages.com/google.html”
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Main\”Start Page” = “http://rnd009.googlepages.com/google.html”
HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main\”Start Page” = “http://rnd009.googlepages.com/google.html”
HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Internet Explorer\Control Panel\”HomePage” = “1′
HKEY_CURRENT_USER\Software\Policies\Microsoft\Internet Explorer\Control Panel\”HomePage” = “1′ Note: In any Gphone.exe files I mention above, “%UserProfile%” is a variable referring to your current user’s profile folder. If you’re using Windows NT/2000/XP, by default this is “C:\Documents and Settings\[CURRENT USER]” (e.g., “C:\Documents and Settings\JoeSmith”). If you have any questions about manual Gphone.exe removal, go ahead and leave a comment.
How to delete Gphone.exe files in Windows XP and Vista:
1.Click your Windows Start menu, and then click “Search.”
2.A speech bubble will pop up asking you, “What do you want to search for?” Click “All files and folders.”
3.Type a Gphone.exe file in the search box, and select “Local Hard Drives.”
4.Click “Search.” Once the file is found, delete it.
How to stop Gphone.exe processes:
1.Click the Start menu, select Run.
2.Type taskmgr.exe into the the Run command box, and click “OK.” You can also launch the Task Manager by pressing keys CTRL + Shift + ESC.
3.Click Processes tab, and find Gphone.exe processes.
4.Once you’ve found the Gphone.exe processes, right-click them and select “End Process” to kill Gphone.exe.
How to remove Gphone.exe registry keys:
Because your registry is such a key piece of your Windows system, you should always backup your registry before you edit it. Editing your registry can be intimidating if you’re not a computer expert, and when you change or a delete a critical registry key or value, there’s a chance you may need to reinstall your entire system. Make sure your backup your registry before editing it.
1.Select your Windows menu “Start,” and click “Run.” An “Open” field will appear. Type “regedit” and click “OK” to open up your Registry Editor.
2.Registry Editor will open as a window with two panes. The left side Registry Editor’s window lets you select various registry keys, and the right side displays the registry values of the registry key you select.
3.To find a registry key, such as any Gphone.exe registry keys, select “Edit,” then select “Find,” and in the search bar type any of Gphone.exe’s registry keys.
4.As soon as Gphone.exe registry key appears, you can delete the Gphone.exe registry key by right-clicking it and selecting “Modify,” then clicking “Delete.”
How to delete Gphone.exe DLL files:
1.First locate Gphone.exe DLL files you want to delete. Open your Windows Start menu, then click “Run.” Type “cmd” in Run, and click “OK.”
2.To change your current directory, type “cd” in the command box, press your “Space” key, and enter the full directory where the Gphone.exe DLL file is located. If you’re not sure if the Gphone.exe DLL file is located in a particular directory, enter “dir” in the command box to display a directory’s contents. To go one directory back, enter “cd ..” in the command box and press “Enter.”
3.When you’ve located the Gphone.exe DLL file you want to remove, type “regsvr32 /u SampleDLLName.dll” (e.g., “regsvr32 /u jl27script.dll”) and press your “Enter” key.
That’s it. If you want to restore any Gphone.exe DLL file you removed, type “regsvr32 DLLJustDeleted.dll” (e.g., “regsvr32 jl27script.dll”) into your command box, and press your “Enter” key.
Did Gphone.exe change your homepage?
1.Click Windows Start menu > Control Panel > Internet Options.
2.Under Home Page, select the General > Use Default.
3.Type in the URL you want as your home page (e.g., “http://www.homepage.com”).
4.Select Apply > OK.
5.You’ll want to open a fresh web page and make sure that your new default home page pops up.
Gphone.exe Removal Tip
Is your computer acting funny after deleting any Gphone.exe files? I recommend using a program like File Recover from PC Tools. File Recover saves deleted files that otherwise can’t be recovered by Windows operating sytem.
Want to save time finding Gphone.exe files? Download Spyware Doctor, let it find the Gphone.exe files for you, and then manually delete Gphone.exe files.
2helpful
The ntvdm cpu has encountered an illegal instruction
I took this from another web site:
Michael Chiew said:
What did you do before this happened? What were your last deeds on the machine before the pop-up appeared?
I think what you're referring to is NTVDM CPU, not NTDVM CPU. Am I correct?
What do you know about 16-bit and 32-bit applications? Well, 16-bit applications are those that must work within the DOS (Disk Operating System) environment, a real-mode arena. NTVDM stands for NT Virtual Dos Machine.
In Windows XP, as in Windows 2000, or Windows 98, there are 16-bit and 32-bit environments (real mode and protected mode respectively).
Windows XP can only operate in 32-bit mode. All 16-bit applications must work within its own theatre of operation, typically, the first MB of physical memory (ram). Conversely, 32-bit applications must function above the first MB memory line. If either of these applications happens to slip into "alien" territory, you get an error message like "something" has encounter an illegal instruction. In other words, the wayward application is trying to slip by the immigration checkpoint.
In your case, updatemgr.exe (I suspect updatemgr.exe is a 32-bit application) has in all likelihood wondered into the 16-bit arena. Hence, NTVDM CPU issues that warning.
Why do you continue to get the message. It's because updatemgr.exe incessantly misbehaves itself on start-up, always trying to load itself into a particular memory address where it is not welcome. Why the persistence? Updatemgr.exe has gone bonkers. It is either corrupted or damaged.
On the other hand, one cannot discount the possibility that NTVDM (NTVDM.EXE) is corrupted or damaged. So your problem lies with either updatemgr.exe or NTVDM.EXE, or both.
There are 2 things you could do.
First, establish who owns updatemgr.exe, Microsoft or some third-party owner. Second, rename updatemgr.exe and see whether the message goes away.
To establish ownership (and the function of updatemgr.exe), do a search for the file.
Click START, select FIND. In the FIND dialog box, type: updatemgr.exe. See the directory in which the file has lodged. In Windows Explorer, get to the file, right-click on it, select PROPERTIES. Who owns it? Is there an indication of its function.
Next, rename the file. Right-click it, select RENAME and rename it to, say, updatemgr.old. RESTART your computer. Do you still get the error message. Not likely.
To clean things up a bit, perhaps it is a good idea for you to replace the current NTVDM.EXE with a new copy. Find out where NTVDM.EXE is. Then, click START, select RUN. Type in the RUN dialog box SFC to run the System File Checker. Insert your OS CD, follow the prompts, extract a copy of NTVDM.EXE and send it to its place of residence. Of course, you should also replace a copy of updatemgr.exe.
That should eliminate your problem for good.
8helpful
7answers
Cannot find regsvr.exe
Download and run this:
http://piyushlabs.googlepages.com/Heal_regsvr1.0.zip
BTW...it's a virus you have. It will get worse if you don't clean it or restore your computer.
5helpful
3answers
AegisE5.dll was not found.
The file bcmwltry.exe is the tray bar process for the Broadcom Corporation Wireless Network software.
You can try eliminating the program from start up.
Click on Start >>Run, type "msconfig" (without the quotes), then click on OK.
When the System Configuration Utility loads, click on the "Start Up" tab, then scroll down to the "bcmwlt.exe" entry and UNCHECK the box next to it.
Click on Apply, then OK, and the computer will need to be restarted. Do it. Upon restart, you'll see a System Configuration Utility warning. Simply choose the option to stop it from repeatedly opening.
This will be fixing your problem
Have a great day!
Pablo :-)
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
