After much surfing I have found the solution to my mondo TV's problem, being at least handy I have removed the "D" board that houses the pair of "STK" convergence Chips, I am sending it off to PTS corp to have it rebuilt, this is IF I can remove the flyback high voltage wire from the distribution block.
I have read time and time again that this wire should be pushed in and rotated 90 degrees to free it from the distribution block, I messed with it for an hour last night, and although it feels like it is spring loaded and I can in fact hear a spring in side the distribution block creaking I cannot free it from the block.
I am ready to don gloves and cut the wire and solder it back together when it is returned if someone doesnt have a better answer.
Thanks for your time.
lj
SOURCE: Replacing STK392-110 IC Panasonic PT-51HX41 51 in. Rear Projection Television?
TV Tech - well another issue has cropped up today. The TV turns on for about 15 secs and then automatically shuts off. Seems like a power supply issue but not sure.. Your thoughts?
SOURCE: STK chips didn't fix my problem
You probably have a bad cap in the horizontal sync circuit. I'll check with mhy Pioneer contact for more details. Stay tuned...
Dan
SOURCE: Replace IC Convergance chip in Panasonic PT-56HX41PF
Enter the tip of a pointed knife between the left side edges of the connector (circled in black in the attached pic) and gently tilt the knife away from the connector. Do the same on the right side. The connector should pop up.
SOURCE: HItachi 43FDX20B Rear Projection TV Convergence Problem
Replace both STKs Use StK 329-180s if set is using110s,120,150s, I havent heard of anyone yet getting shocked from replacing ICs.
SOURCE: SAMSUNG HC-P4752W 47" TV Convergence problem
Resistors most likey...look for burnt or discolored resistors near the convergence chips.
