Sony KP-65WV600 65 in. Rear Projection HDTV-Ready Television
Problems with Sony KP-65WV600 65 in. Rear Projection HDTV-Ready...?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Sony KP-65WV600 65 in. Rear Projection...
Problems
& Solutions
Manuals
& Guides
Repair
Service
Reviews
& Ratings
Warranty
& Spec
Troubleshooting and Support
Solved Problems for Sony KP-65WV600 65 in. Rear Projection HDTV-Ready Television RSS Feed
View More Results for Sony KP-65WV600 65 in. Rear Projection HDTV-Ready Television
Questions and Unsolved Support Problems
Unsolved Problems for Sony KP-65WV600 65 in. Rear Projection HDTV-Ready Television RSS Feed
Answer
I have a Sony 65" projection TV. The screen turns green and then after a few seconds goes... (More)
Answer
My Sony's Convergence AD Board (Regi Correction) was replaced once and I suspect the same problem... (More)
Answer
sony kp-65wv600 projection tv error code 7 (light on front flashes 7 times) after picture turns... (More)
Answer
Started with red lines, then red picture and now the standby is blinking 5 times. TV still turns on... (More)
Answer
Help needed! I had a blue tube replaced (had the blue line across the screen no other color or... (More)
Answer
The Red has cured downward on the ends of the screen, Top and bottom, and especially noticeable when... (More)
Answer
Hi All! My Sony RP tv is 4 years old and just recently the color is off. The color of people's faces... (More)
Find a Manual
Sony KP-65WV600 65 in. Rear Projection HDTV-Ready Television Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
Tips & Tricks
(Post a New Tip)
Mitusbishi shuts off instantly...
Most of the Mitsubishi rear projection sets made from about 2000 through 2006 have a self diagnostic check feature. It will indicate if there is a... written by SD Tech
PANASONIC CONVERGENCE DO IT YOURSELF REPAIR
So many people ask me about this here are my Instructions if convergence will not adjust and or is skewed: PANASONIC CONVERGENCE... written by SD Tech
Solution for Video looking whiteish, dull, or too red
Here are some of the most common symptoms and examples of a convergence problem. This is a very common failure on Projection TV sets. Screen looks 3D... written by Ecollier2012
Why my TV does not start up and remains in standby?
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also ensure that the fault is not coming from a faulty receiver... written by ginko
The Fl231 PROBLEM(CONVERGENCE NOT IN CUSTOMER MENU) ITC22 chasis
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and... written by willtab
Updated! Convergence Problems & Solutions - With example photos
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV... written by Ecollier2012
How To Fix A Convergence Problem
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen... written by Ecollier2012
Distorted Video - Convergence Problems - 3D Looking
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the... written by Ecollier2012
WikiManual
(Post a New Chapter)
Be the first to Post a New Chapter
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for KP-65WV600 65 in. Rear Projection HDTV-Ready Television
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Featured Listing
Ratings for the Sony KP-65WV600 65 in. Rear Projection HDTV-Ready Television
Owners Recommend
out of 1
Reliability
Ease of use
Value for Money
Find a Warranty
Warranty Information for Sony KP-65WV600 65 in. Rear Projection HDTV-Ready Television
Specifications for Sony KP-65WV600 65 in. Rear Projection HDTV-Ready Television
Key Features
Screen Size
65 inch
Display Format
1080i (HDTV) · 480p (EDTV) · 720p (HDTV)
Digital TV Standard
HDTV-Ready
Projector Technology
CRT
Display Capabilities
Aspect Ratio
16:9
Built-in Tuner
NTSC
Remote Control
Remote Control
Standard
Image Quality
Velocity Scan Modulation
With VSM
Comb Filter
3DYC / 3D Digital
Adjustable Color Temp.
With Adjustable Color Temperature
Audio Features
Audio Output
Variable / Fixed
Audio Type
Stereo
Sound Leveler
With Audio Leveler
MTS Stereo
SAP / MTS Stereo
Secondary Audio Programming (SAP)
With SAP
Technical Features
Picture in Picture
With PIP
Parental Control
V-Chip
Sleep Timer
With Sleep Timer
Energy Star Compliant
Connectors
Headphone Jack
Without Headphone Jack
Rear Input Connectors
Component x 2 · S-Video x 2 · Composite x 3 · DVI x 1 · RF x 2 · Audio (RCA) x 3
Front Input Connectors
Composite x 1 · Audio (RCA) x 1 · S-Video x 1
Rear Output Connectors
Composite x 1 · RF x 1 · Audio (RCA) x 2
Memory Card Slot
Memory Stick
Screen Text
OSD Languages
English · French · Spanish
Channel Labels
With Channel Labels
Closed Caption on Mute
With Closed Caption On Mute
Speakers
Number of Speakers
2 Speakers
Speaker Power
2 x 20 Watt
Dimensions
Depth
28.88 in.
Height
59.63 in.
Width
60.75 in.
Weight
299.81 lb.
Warranty
Overall Warranty
1 Year
Tube Warranty
1 Year
Sony Contact Information
Main support number800-488-7669
Describe your problem:
Top Projection... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
