Drained the machine. I pulled on the door lanyard to unlock the door. Cleaned the drain and put the hose and lanyard back. Now when I start the machine makes an intermittent clicking sound , possibly the door latch trying to lock. How do I fix?
Possible this could be jammed lock and is advisable to check the lock settings.
Please check this link for tips.:
Door lock
SOURCE: Door locked open
Tool: We cut a piece a wire about 10 inches long from a wire clothes hanger. On one end we bent 1/2 inch of the wire in a 90 degree angle with needle nose pliers. On the other end of wire we put another bend at least three inches.(this end will be your handle end) Process of using homemade tool to release latch: Make sure washing machine is on a wash cycle. Use flash light to locate latch in the locking catch. Insert the small bend of the tool into the locking catch. Then hook onto the latch and pull out --apply a small amount of pressure -- about three lbs of pressure) Then at the same time you are pulling, press in on the door release button (the little white button above the latch hole where you now have the wire inserted). As your are pulling with little pressure on the latch, hold the little white button in and press the start /stop button. You should hear the door lock. Let machine start working. (about ten seconds) Now push start/stop button again and you should hear door lock release. Your lock catch should give away. This worked for us.
SOURCE: Bosch WFR2460 Leaks
are you sure it only happens in the spin cycle? and is the leak comming from the bottom front of the washer? most front laoders will leak due to a tear in the belows. that is the rubber boot that seals the washer tub to the front panel. if there was a hole or a tear in the bellows it should have a leak inthe wash cycle also. but there are also other possibilitys too.but its strange to only leak in a spin cycle due to the washer is extracting the water and not adding it. so check and see if it leaks in the wash cycle to and get back to me and we can go from there. looking through my training manual i dont see what could cause a leak in just the spin cycle
SOURCE: have a Bosch WFMC 3200UC and gives a E04 error.
In order to unlock the door on this machine you must first turn the cycle knob to a cycle that was different than the one you were on. The machine should then reset and the door should unlock.
SOURCE: Bosch WFF1201 Washing Machine, wont drain
To access the pump filter, remove lower plastic panel at front of washer, there you will see the filter, unscrew filter cover anti clockwise, remove and clean filter.
You will probably find that whatever was causing the clicking noise is something in the filter.
If you can't see anything in it , then have a look inside the pump housing before you replace filter.
Plz rate my solution .
Thanks.
SOURCE: Bosch WFF1800 - not spinning
HI,
move the kicking plate on the front-bottom of the machine. You will see
o circular lid there, turn it on anti-clockvise to open. All of the
water blocked will come from there, be careful. Look carefully that
there are some objects blocking the water draining. Then turn on the
machine on draining programme, the plastic rotor should turn fastly
when the machine is on. If it is not running, change the pump motor. If
it is running, but machine is not draining again you can understand
that there is an objeck stuck on the hose between drum and pump motor.
Lay down the machine on its rear facade, you will see a large and black
hose between drum and pump motor. When you remove it, you will see that
there is something that blocks water running.
thank you for using fixya,rate my answer,
vijay
