I encounter that problem ....maybe you install the printer installer not properly.... do it by step.... and make sure the usb port is the one u choose...
Go start menu, control panel, select sound and audio devices, make sure check mark is on place volume in the taskbar to the left, if not check it and click apply.
hi you can reset it to its original settings by pressing in the reset button on the back , once reset just type admin = user name password = password
then you should be able to put it back the way you want it...hope this helps
are you referring to low frequency hum? that's a ground issue..check all your power cables, and eliminate the two prong approach..and plug your speakers into the wall directly to get the ground action
are you using USB?
