Have 50-inch pioneer smart tv the remot dont work
Hello Michael, indicate the model of your TV pioneer
Test if the remote control works, remove the batteries, observe the contacts of the batteries, which are clean, otherwise, clean them so that the batteries make good contact
Once the batteries and contacts have been checked, put them back
Take your cell phone, put it in camera mode and point the emitter LED of the remote control to the camera, press the keys and see if the emitting LED lights up, if so, try directly with the TV
if it does not turn on, you could carefully disassemble the remote control and clean the contacts and the rubber keyboard internally, Do not Use Alcohol to clean
the rubber keyboard, you can clean it with warm water and detergent then let it dry very well, the contact plate, you can use a cloth with a little liquid to clean the glasses, the idea is to remove the rubber residue that is on the contacts
then arm again and try, if not you have results consult a specialized technical service and if you try, you see in the camera that the LED turns on, but the TV does not, then it takes the two devices to the specialized technical service
I hope you can solve the problem
Greetings Franco Dosil
Hola Michael, indica el modelo de tu TV Pioneer
Prueba si te control remoto funciona, s?cale las pilas, observa los contactos de las pilas, que se encuentren limpios, sino es as?, limpialos para que las pilas hagan buen contacto
Una vez controlado las pilas y contactos,vuelve a colocarlas
Toma tu celular, pon en modo c?mara y apunta el Led emisor del control remoto hacia la c?mara, presiona las teclas y f?jate si se ilumina el Led emisor, si es as?, prueba directamente con el TV
sino prende, podr?as desarmar con cuidado el control remoto y limpiar internamente los contacto y el teclado de goma, No Uses Alcohol para limpiar
el teclado de goma, lo puedes limpiar con agua tibia y detergente luego d?jalo secar muy bien, la placa de los contacto, puedes usar un pa?o con un poco de liquido para limpiar los vidrios, la idea es sacar el residuo de goma que hay sobre los contactos
luego arma nuevamente y prueba, sino tienes resultados consulta a un servicio t?cnico especializado y si pruebas, ves en la c?mara que el Led se enciende, pero el televisor no, entonces lleva los dos aparatos al servicio t?cnico especializado
Espero puedas resolver el problema
Saludos Franco Dosil
