SOURCE: I can't hear any speech when I play a DVD, but I have all other sound.
Yes what you heard is correct,look for center speaker connection.If it is correct then connect it thru coaxel or digital out and see.
SOURCE: Kenwood KA-994 Amplifiler no sound from rear speakers.
SOUND FROM YOUR SURROUND SPEAKERS COMES BY BECAUSE OF PROCESSING THAT TAKES PLACE IN YOUR SURROUND CIRCUITS. IF THE SURROUND MODE IS ACTIVATED AND U GET NO EFFECT AND U SURE YOUR SURROND SPEAKERS ARE OPERATIONAL AND FULLY FUNCTIONAL. THEN THE PROBLEM LIES WITH YOUR SURROUND DECODING IN YOUR UNIT. REFER TO QUALIFIED SERVICING AGENTS.
SOURCE: cant get my viera linked panasonic to play through surround sound
I had the same problem, so i contacted panasonic, I am including the email they sent me.
For connections of audio, so that you can hear all tv audio through the
surround system, connect either an optical audio cable or red & white
analog audio cables from the tv to the home theater. If you are using
optical audio, there is a plug on back of tv labeled for digital audio
output and an input on the surround sound system. If you plan on using
analog red and white, use the PROG OUT red and white output jacks on the
back of the tv to the AUX input on the home theater.
For video connections, to get HD you will need to be using either HDMI or
Component cables. HDMI is the cable that will provided 1080p signal (the
best HD signal), but if the source does not output 1080p, then your tv
will not display 1080p. Most cable boxes output at 1080i or 720p when on
HD stations. This signal still provides great picture quality, but HDMI is
not needed to get these HD signals. You can use component cables for your
cable box and the DVD player output to the tv for video. HDMI might give
you a slightly better picture quality but the signal will be the same.
To make the connection, you will want to connect from the cable box to the
tv (component or hdmi). Also from the home theater system to the tv using
hdmi or the video cables from component (red, blue, & green cables).
We hope this information is helpful to you.
Thank You,
Panasonic Consumer
SOURCE: No sound through the Panasonic cinema surround sound on TV
Had a similar problem mate. I solved it by connecting the tv to the PT460 system with a scart lead. You then have to have the AV channel selected on the PT460 system to listen to the tv. You will always have to have the AV channel on the PT460 selected to listen to any sound transmitted through the tv - be it playstation/xbox or any other device that you may connect in the future with HDMI leads or otherwise. Hope this helps
