Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer Logo
Posted on Oct 18, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My bosch nexxt 500 series washer won't spin
Washer will go through cycle add water, drain water but won't turn the drum at all
  • 10 more comments
  • mgonfishin Dec 02, 2008
    My machines does the same thing and also sometimes it just fills with water then drains and just sits there.
  • Anonymous Mar 14, 2014
    Rotates but doesn't spin out water
  • Anonymous Mar 15, 2014
    won't drain
  • Anonymous Mar 23, 2014
    the machine only does this once in awhile. other then that the machine runs ok.
  • Anonymous Mar 24, 2014
    takes on water but will not start the cycle.
    the washer will take water but will not start
    will not start or pump out the water
    the **** had a dime in it cleaned it out but not sure if the pump is running.
    the machine will not start but will take on water. could it be the motor control board?when you push the start bottom it will click but will not start.
  • Anonymous Mar 25, 2014
    how do you pull the motor out of a bosch next 500 washer.
  • Anonymous Mar 26, 2014
    the washer will not start the drum but will take on water. thought it was the drain pump replaced it. now it will pump out the water but will not start.
  • Anonymous Mar 28, 2014
    it won't drain or spin unless there is nothing in the washer
douglas smith
Level 3:
President:
  • Master 1,462 Answers
  • Posted on Oct 18, 2008
douglas smith
Master
Level 3:
President:
Answers
1462
Questions
0
Helped
898751
Points
3964
Possibly the motor brushes.
take back panel off. disconnect motor. remove bolts holding motor in and take out motor. check condition of brushes
1helpful
Bosch 500 series wfmc3301 bosch washer does not stop running the water during a cycle . even will do it with the spin and drain cycle. Even attempting to turn the washer off it will still run and then once...
You have a bad water supply valve which is struck in the on position-this valve is mounted inside the machine right where you attach the supply hoses-cheers Denny
Spin cycle not working
When you say the spin cycle is not working do you mean that nothing works in the spin cycle. For example: Does the drum move or does it move and but the water isn't drained out?
Nexxt Washer Problem
timer not sending signal, or bad transmission
3helpful
The water won't drain from my Bosch Nexxt 500 Series Washer machine
I solved the problem by using a sump pump to drain most of the water, then I removed the cover plate on the lower front right of the machine to get access to the drain plug. Upon removing that, some water flowed out but not too much, I found a sock jammed in there which wasn't allowing the drain or spin cycle to work properly.
Interestingly, the machine's manual says that the cover plate is only to be removed by a Bosch authorized service repair representative. Saved about $150 by simply doing this myself.
Bosch Nexxt 500 Series Washer Will Not Add Water
during a normal wash cycle the washer stopped and gave an e;4 error code
Bosch front loading washer nexxt 500 won't pump out water on the spin cycle
could be drain hose is not high enough. I had the same problem and when I raised the hose it worked fine.
1helpful
3answers
Bosch Nexxt 100 Series washer
Look into your manual, clean outlet filter & refit. Machine will not spin out if filter is clogged.
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
