Mitsubishi wd 52525 Problems, but no blinking lights.
When tv was turned off, everything was working fine. Turned tv on next morning and, Ant.1 showed a black screen with white dots, and computer garbage (It wasn't just static, you can tell it is computer generated lines), moving around and was colored green,
The other devices, (ps3 and vcr) had blue screen with a basketball sized ghost floating around in the middle of the screen. Sometimes, audio partially works on ant. 1. I can select demo mode and the picture comes in almost perfect, except for the floating ghost is still present.
There are no flashing lights on the front panel, just the one solid green light.
i have thought about this since you first posted it. if the demo is good then the light engine is ok. it sounds like a problem in the chassis. probably on the DM and the terminal board. to repair the chassis would cost about $250.00 plus shipping. go to www.tv-techs.com
t is more than likely your television has had a lamp failure. Part number 915P020010 is the right part for your tv. Remove the lamp, your instruction book will tell you where it's located. Check the anode of the lamp, if fracture find a lamp on ebay vendors. Try niosales.com They are my trusted vendor for new lamps.
This is just a shot - but it worked with my Sony (same problem).
Pressed remote power on button AND held Power button on TV on at the same time.
Set clicked 4 or 5 times and then came on....
Other, most have a (VERY small) reset switch on the rear - near where the power cord enters the TV... Use a flashlight and a mirror to locate it on your set....
If you hear a whining noise, the odds are it is the color wheel, the bearings are bad in it and will need to be replaced as a whole unit, kinda pricey, my suggestion, sale the bulb and all boards in it and which should fetch about 400+ and invest in a new TV, a color wheel is pricey unless you can find a deal
the circut that detects the bulb has been also failing in these sets
and the conversion chip that controls the picture , and the transformers are not putting out the full power they are supposed to.
this set will need to be tested to determine the exact cause or causes
