It's a bit late, as I guess you have moved by now!
The best way to drain fully is to remove the outlet hose and let the machine lean backwards against an outside wall so that all water drains out.
Poppa
http://www.cdbaby.com/cd/poppamadison
SOURCE: drain line lg tromm
its a pretty complicated process to take off the front panel, you will need special tools for this problem, i would bring it to a professional, the easist way is to lay it on the back side and go from there, if not like stated above bring it to a pro.
ps:drain lines hardly go bad on LG's hmm,if it's leaking then it might be the internal supply lines on the top.
just a hint,
shoots dave
[email protected]
SOURCE: my front load Tromm LG
oe is an error code for pump problem disconnect power cord open small door on lower front of cabinet pull little tube out and plug from tube and drain water in to bucket after water is drained unscrew cap of pump to clear out any obstructions reinstall the cap and plug and give a test run
SOURCE: wont drain
I would guess that the impeller has come off the pump motor shaft. You can disassemble and push it back on, but it will come off again. I don't know if some type of adhesive would work, but I just replace the pump motor.
Drain water from small drain hose (or by removing filter) Remove the screw in the plastic recess by the filter, then use a putty knife on the left or right side to pop out the recess. Remove two more screws holding pump body to front frame of washer. Pull washer about 18 inches away from wall and tilt it back to lean against wall. There is a plastic locking tab holding the pump body to the plastic washer base, but don't worry if you break that, as the screws (removed earlier) will hold the pump back on just fine. Pump motor is held onto pump body with three more screws. Replace pump motor with a new one and reassemble. On a difficulty scale of 1 -10, this one might rate a 3.5 or a 4. Not too bad.
SOURCE: lg front load washer leaking from bottom of machine
I just fixed this problem - there is a rubber hose that hooks the bottom of the drum to the drain and recycle pumps - it is ribbed and it developed a hole. To confirm and repair (repair can be done from the front of the machine)
SOURCE: washer is showing "TE" error even after replacing the thermistor
Try pressing spin speed and soild level at the same time. Is the temperature about 10 degrees C over the the selected temperature? If no, then try replacing the main board.
Also make sure the thermister isn't loose. That could cause your problem.
If the main board doesn't fix it, then you have to replace the heater assembly.
Im actually looking the the service manual your unit as we speak.
