Good day!
First
of all,before you proceed to the minor/major troubleshooting try to
check first the cable signal and connection of it,if you are cable
subscriber.Another thing is to play any movie or recorded shows to your TV to make sure that the problem is
on your TV or on the signal.
If you already play the movie and the problem is still there.
Follow the procedure of troubleshooting to fix the problem:
NOTE: Always double check the solder parts when you replace any parts or components to avoid short circuit or major damage.
Just add a comment for more query or if the problem is still unsolved.
I hope this solution will be helpful to fix your problem.
Thank you and good luck.
My tv is an HD 1080 series. I have noticed that when the tv is turned on, the picture is fine, bit between 15-20 seconds it curves again. It switches back and forth between good and bad. Are you confident that it is the the convergence IC? If so, where would I be able to get one. I am in a rural area and the nearest metro is a couple hrs away. Is there anywhere you would suggest where i could send the motherboard or component to be repaired?
