My Sony KP-34T75 Projection TV flashes green lines and makes a clicking sound every once in a while....
(More)
My Sony KP-34T75 Projection TV flashes green lines and makes a clicking sound every once in a while. It happens when watching the cable or DVDs. It is very annoying
I have a Sony KP-65XBR10W that had a blinking light on the front, either blnking 9 times or...
(More)
I have a Sony KP-65XBR10W that had a blinking light on the front, either blnking 9 times or continuously. I replaced the fuse and it no longer blinks, but does not respond to anything. Where should I start looking? I believe the problem is on the G-board/power supply. Let me know if you can help. Thanks
I picked up a Sony KP-65XBR10W in it's non-working state. The tv had a blown 6.3a 125v fuse which...
(More)
I picked up a Sony KP-65XBR10W in it's non-working state. The tv had a blown 6.3a 125v fuse which caused the red light on the front of the tv to blink continuously. I went to radio shack and all they had were 6.3a 250v fuses, so I tried one. Now the set has no response. I hope I didn't screw anything else up by not using a 125v fuse.
tv will normally come on when cold. Once warm, the video on the tv will disappear and you will get 5...
(More)
tv will normally come on when cold. Once warm, the video on the tv will disappear and you will get 5 blinks on attempting to restart before tv trips out.
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and...
written by willtab
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also
ensure that the fault is not coming from a faulty receiver...
written by ginko
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV...
written by Ecollier2012
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen...
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the...
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
Lamp cover error 3 times - Lamp cover is not fastened securely - No picture/No sound Fan error 4 times - Fan1-4 Power is not supplied.(G2 board) - Fan...
written by SUPERMAN_B_1
Call 1-800-447-1700 Consumer Electronics Technical Dept. GE sold out to: Thomson, Inc. P.O. Box 671988 Marietta, GA 30006-0034 I called this company...
written by jrleopards
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
