20 Most Recent Mitsubishi VS-55609 55" Rear Projection Television Questions & Answers
ano po b ang address ng GMA mag papadala po kasi ako ng letter para po sa batang gustong mag hanap buhay di ko lang po alam kong may magulang pa sya o wala na d ko din po sya kilala gusto ko lang po sya mabigyan ng magandang buhay para sa kinabukasan ng isang bata!!!!
Mitsubishi... | Answered on Mar 24, 2013
Punta ka sa EDZA Kamuning, malapit yun sa trinoma, or email mo na lang www.wishkolang@gmanetwork.com
Mitsubishi... | Answered on Sep 02, 2012
See link to owner manual already given on another question posted here.
Mitsubishi... | Answered on May 15, 2012
Hold the lock button for several seconds to release and I have already given you a link to the free owner manual for this set.
Set will turn on either with remote or front power button---if when turned on power light goes off after a few seconds set is in shutdown---set may have the self check feature--let me know with a comment if you want that info--I have already given you a link to the owner manual.
This is a link to the manual which you can download for free--note pages 39 and 64 which deal with unlock of front keyboard and also reset with the remote.
http://www.retrevo.com/support/Mitsubishi-VS-55609-TVs-manual/id/276bh842/t/2/
Try the self check when power light goes off, on front press and hold both the menu and input buttons for at least 5 seconds and let both go.
Power light will blink a two digit error code like 2 blinks,2blinks, pause and repeat it several times.
What error code do you find?
SD TECH
Mitsubishi... | Answered on Oct 18, 2011
dear wish ko lang! ako po c harry tunacao nasa saudi po ako gusto ko sana manghingi ng tulong po sa inyo ate vicky yung tatay ko kc matanda na gusto ko sana ipa gamot kulang kasi yung pera ko!tapos yung nanay ko wala ring trabaho kulang rin ang suporta ko sa kanila.tapos yung sahod ko maliit lang d2 sa saudi.sana ate vicky matolongan u po ako! maraming salamat po!
Mitsubishi... | Answered on Oct 10, 2011
the convergence board is bad you need to replace the convergence ICs', to have it repair you are looking at 300-400 and if it was me I just buy a new LCD.
Mitsubishi... | Answered on Aug 18, 2011
probably need to replace the convergence ICs inside the TV. The Ic is about 2" x 3" and mounted on large aluminum heatsink. Usually 2 or 3 (depends on model)
Mitsubishi... | Answered on Aug 02, 2011
On a Mitsubishi remote control when it asks for the password you would simutainiously press the "9" and "QV" buttons until it unocks, then you would change the password. I am not sure this will work on a universal remote. I hope this helps anyway : )
Mitsubishi... | Answered on Jul 26, 2011
This may be loose solder if it occurs after a few hours. Otherwise if its permanent its the convergnce modules.
Mitsubishi... | Answered on May 20, 2011
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
Mitsubishi... | Answered on May 01, 2011
Mitsubishi VS-55609 55" Rear Projection Television Logo
Popular Tags
58 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Mitsubishi Televison & Video
Most Popular Question
address wish ko lang
  • Televison & Video
