D-Link DIR-615 is a Wireless N 300 Router, which delivers great performance, network security and coverage, etc. I have deployed a similar D-Link Router for about 10 Wired and wireless client PCs in a network for file, print and internet sharing and it performed without any issues. So, I think, you can add additional IP cameras and it should work fine.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Testimonial: "It seems great. And it works just fine. But the speed gets a little bit slow."
I dont think their is a limitation of it, the only problem that you might be encounter is the bandwidth of your internet, co'z each camera which uses internet is also using bandwidth signal to distribute the frames that will create an images, so if your camera are connected to the internet then their might possible scenario that will slow your internet especially if the recordings of an image is realtime. Just a thought only hope it helps thanks.
I agree!, that there is no such limitation of the number of clients per router. However, the total bandwidth is divided among the clients. Thus, more clients means less bandwidth/ data rate for each client. In case of cameras all clients are utilization bandwidth/ router resources simultaneously, which is resulting in a somewhat compromised performance (as stated by Matt). I'm glad for Charlie's interest in the matter. Hope it all better assists the Fixya users. Thanks
CreativeTECH
HP says to use the Vista drivers. You have to install it a a local printer follow these steps....
1. Make sure the printer is turned on and connected to your network. Verify that you can access the printer's internal web page by browsing to its IP address before continuing. Print a network config page or make note of the IP address and Name. (should be a static IP)
2. Click >> Start >> Control panel >> Devices and Printers.
3. Click the Add a printer
4. Select Local printer
5. Select Create a new port and select Standard TCP/IP Port and click Next button.
6. Under Device type, select TCP/IP Device. Under Hostname or IP address, enter the printer's host name (found on the printer's network configuration report the generated above). Click Next.
If you get a message about Additional Port Information Required, then the printer was not found using the host name. You can go back and retry or using the printer's IP address instead of the host name.
7. Select HP or Hewlett-Packard from the list of manufacturers and select and select your printer model. Click Next.
If your printer model was not listed, then select Have Disk, browse the HP CD that came with your printer and select the first file that starts with hp and ends with inf.or use currently installed driver if you have teh correct on installed. Click Open then OK. Select your printer model. Click Next.
8. It will ask for the Printer name -- enter a new name or use the existing one. This will be the name of the printer that you select from other applications.
9. You may be asked to share the printer. Make a choice and click Next.
10. The Print Test Page box appears. Go ahead and print it.
11. Click Finish.
