SOURCE: Replace Light Engine
I have the 62HM95 and my light engine went out between 2 and 3 years. I will never buy a Toshiba again. I have had nothing but trouble with the components and the customer support. I am in a class action lawsuit with them, but I doubt very much will come of it.
As far as fixing your TV I was in the same delimma as you. I wasn't willing to pay nearly $1000 to get this set repaired when it already cost $3000 and it started having problems within the year and major issues after 2-3 years. I was willing to risk a couple hundred bucks that I could fix it myself. If you aren't very handy with taking things apart and putting them back together, by all means don't do this. It is pretty easy to do and you can figure it out as you go, but I wouldn't suggest you doing this if you weren't willing to take the risk of really messing it up.
I didn't go to Part Store.com because they wanted $456 and then when I finally decided to do it they raised the price to $556...No way, I found http://www.tristatemodule.com/html/light_engines.html and you can get a light engine that is refurbished for $250, or you can have your light engine refurbished for $200, which is what I plan to do if this one fails in the next two years. I looked at their site and it doesn't show that they have any in stock, but they may if you call. I wasn't comfortable sending mine off to be refurbished because I wasn't sure if I would remember how to put it back together, and I'm glad I didn't because the one they sent me didn't work, which sucks, but it happens. I called them back and sent it back to them and it worked fine. All in all, I had no instructions or any other help besides my memory of how I disassembled it and it only took me an hour at the most, not really too hard.
The only other issue I had with them and it really wasn't with them as much as Toshiba is, I received a light engine for a 46" model, which when I talked to Toshiba they swore up and down that it wouldn't work, when I talked to TriState about it they said that Toshiba would say that and they had used it in 1,000's of 62" models and it's worked fine. After they replaced the broken one they sent originally, the new one worked fine and is still working brilliantly and I have my original 62" light engine to get refurbished if anything should happen again. Their shipping time was good and when I returned the product to them, I received a working part pretty quickly.
For $250, this would be the only way I would go. If this hadn't worked, I probably would have just went out and got a different TV. I hope this helps.
Michael
SOURCE: yellow light blinking - blank screen - won't turn on
The problem is with the signal board. Basically, it is not allowing the power signal to go from the on button from the set or the remote to the TV. I am having the exact same problem with my 42" LCD Regza. Currently, if you are under warranty, Toshiba does not have these in stock. They will not have them available to send until early January. My TV has been at the repair shop since December 4th. I am very upset as I won't be able to watch the bowl games in HD. If your set is still under warranty then call Toshiba help line at 800-575-5469. You will need the model number of yout TV that is listed on the front of the owner's manual. They are:
27HL67
32HL67
32HL67U
37HL67
42HL67
The first number will be the giveaway as to which model you have. It is the size of your set. They will ask you to try a hard reset. (Hold pwer button down for 5 seconds until you see the yellow light go solid and go off.) This will most likely not work. If it does, you are lucky. I found that if you unplug the TV for an extened period of time, ie overnight, ity may come back on. It will eventually give out completely though. Better to get the problem addressed with the manufacturer. If you are not under warranty then I do not know what to tell you. Right now I am searching the internet to see if I can find this part to maybe purchase myself. Only if it is not too costly. If I find anything I will post here for all. If you have any questions, feel free to email me a [email protected] and I might be able to give you more details on your problem. Good Luck.
WJ
SOURCE: 50HP95 Toshiba Plasma TV No power but blinking power light
To eliminate power in as a problem get a small battery backup type UPS. This will eliminate power surge spikes, brown outs and for short time periods blackouts. Yes - these TV's are suseptible to power problems.
SOURCE: i have 3 blinking lights and tv wont turn on
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also
ensure that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem with no receiver box
or dvd connected.
If that does not work, and you keep having a flashing
led on front of the TV, and tv turning off by itself after a while,
that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The
internal circuits are jammed because of electrostatic
charges accumulating on capacitors, or because of a wrong voltage read
by the main chip on your monitor controller board. this started the
protection circuit.
2 The protection circuit detected a wrong
voltage or abroken contact, identified an internal fault and kicked in
, startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults
that can occur are a blown capacitor on power board, a
convergence IC has blown, or a fault on Digital board.
Check also
the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you
can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
SOURCE: Blinking yellow light ,no picture or sound.
You have done all you can do. If you had a power outage, when the power came back on a it surged and probably caused a Power Supply problem or something in the micro controller to fail. Either way it 's not good. I would call Toshiba and let them guide you to a Service Facility that can check it out. Depending on your Homeowners Insurance, repairs could be coverd or unit be replaced depending on cost to repair.
Sorry I am not able to help further,
skyassoc
If the power light blinks slowly,
you've tried to turn on the TV during
the lamp cooldown cycle. Wait
approximately 30 seconds, and the TV
will turn on automatically.
If light blinks, pauses for about a
minute, and blinks again: the lamp is
trying to turn on (TV will turn on
when successful). If TV doesn't turn
on and sequence continues, the lamp also
needs to be replaced.
To order lamp call 1-800-338-0376.
Have your TV serial number
and lamp type available (you'll
find this information on the
sticker that's on the right side of
the TV).
OK.
