Sharp Aquos LC-32G4U 32 in. HDTV-Ready LCD Television
Problems with Sharp Aquos LC-32G4U 32 in. HDTV-Ready LCD Television?
Troubleshooting and Support
Solved Problems for Sharp Aquos LC-32G4U 32 in. HDTV-Ready LCD Television RSS Feed Post a New Problem
turn off closed caption on...
We just bought the new aquos and hooked up the hdtv, but now in most of the HD channels closed captions show up and we...
12 Solutions
Sharp aquos lcd screen goes blank
Sharp aquos tv screen goes blank. My sharp lcd tv sometimes goes black.  The sound still works and you can change...
8 Solutions
green vertical line on the right side of...
ive got a single vertical thin line on the right side of my sharp aquos screen
2 Solutions
Blinking power light.
I turned on my Sharp Aquos 32" HDTV last night for the first time. The setup screen came up for just a moment and...
2 Solutions
sharp aquos lc-32
One year old television cuts out picture immediately after start-up and continues in sound only. About ten re-starts are...
1 Solution
Sharp Aquos LC-32D62U Problem
I have had this TV for 4 days. It was working fine, now all of a sudden the power comes on but I get no picture. I...
1 Solution
SHARP AQUOS 32 INCH FLAT SCREEN
THIER IS A LETTER K ON THE SCREEN THAT WONT COME OFF. AND ALSO THE VOLUME ONLY WORK AT LOWEST, MIDWAY AND LOUDEST NO IN...
2 Solutions
Unsolved Support Problems
Unsolved Problems for Sharp Aquos LC-32G4U 32 in. HDTV-Ready LCD Television RSS Feed Post a New Problem
standyby mode
Our television will not turn on. When you hit power, the green light and TV clicks on like it wants to turn on, but then...
Post a Solution
Sharp Aquos LC-32G4U LCD TV
I turn the TV on it turns on but the screen is blank and there is no sound for about 20 seconds then it turns itself off...
Post a Solution
LG LCD 32"television red vertical...
LG LCD 32" tv red vertical block down right hand side of screen
Post a Solution
thompson 40kw611s rear progection
when i turn it on the on off light flashes but dosnt come on, do not use a arial conecton as i have virgin tv please...
Post a Solution
I want to have close captions
Just installed our new LC-32D62U aquos, and wanted to have the close captions, I hit the button on remote and is not...
Post a Solution
thomson 40KW611S
tv switches into standby & flashes error code 31 & 62 please advise what problem could be
Post a Solution
sharp tv question
Did you ever get the problem with the analog screen resolved? I have the same problem. Thanks
Post a Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
Screen Size32 inch
Digital TV StandardHDTV-Ready
Flat Panel TypeLCD
Display Resolution1366 x 768 pixels
Display Capabilities
Aspect Ratio16:9
Built-in TunerNTSC
Display Format1080i (HDTV) · 480p (EDTV) · 720p (HDTV) · 480i (SDTV)
Remote Control
Remote ControlMultibrand
Image Quality
Contrast Ratio800:1
Comb Filter3DYC / 3D Digital
Brightness450 cd/m²
Output Color16.77 million colors
Viewing Angle170
Audio Features
Audio OutputVariable / Fixed
Audio TypeVirtual Surround
MTS StereoSAP / MTS Stereo
Secondary Audio Programming (SAP)With SAP
Technical Features
Picture in PictureWith PIP
Parental ControlV-Chip
Sleep TimerWith Sleep Timer
Energy Star CompliantEnergy Star Compliant
Connectors
Headphone JackWith Headphone Jack
Rear Input ConnectorsComponent x 2 · DVI x 1 · Audio (RCA) x 2 · Composite x 2 · RF x 2 · 1 x RS-232C · HDMI x 1
Front Input ConnectorsComposite x 1 · Audio (RCA) x 1 · S-Video x 1
Rear Output ConnectorsComposite x 1 · Audio (RCA) x 1 · S-Video x 1
Memory Card SlotPC Card
Screen Text
OSD LanguagesEnglish · French · Spanish
Speakers
Number of Speakers2 Speakers
Speaker Power2 x 10 Watt
Dimensions
Depth2.77 in.
Height18.89 in.
Width31.3 in.
Weight28.7 lb.
Warranty
Overall Warranty1 Year
Sharp Contact Information
Main support number1-800-237-4277, 1-800-BE SHARP
Support FAX1-630-378-9981
Sponsored Links
Loading problems.
Top Experts
Ask Me
circuitci Guru
9 solutions
Ask Me
pishta68 Wiz
3 solutions
Ask Me
SparkGap Wiz
1 solutions
Repair Service
Find Flat Panel TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
