20 Most Recent Sharp Aquos LC-46D62U 46 in. LCD HDTV Questions & Answers
am not sure on size service manual doesnt say but there 2 1/2 long.
Sharp Aquos... | Answered on Jun 12, 2018
Failing power supply
Sharp Aquos... | Answered on Feb 19, 2018
OPEN THE TV AND BLOW IT OUT ..THOSE BARS ARE THE EFFECT OF DUST INSIDE THE UNIT CLEAN OUT AS WELL AS YOU CAN AND THAT SHOULD FIX
YOUR PROBLEM
I’m happy to help further over the phone at https://www.6ya.com/expert/jovani_c02b023fe087f6cd
Sharp Aquos... | Answered on Feb 06, 2018
If your TV has a menu button, go into the menu and try setting the input of the TV to the jack that you connected your cable to. Sometimes the TV will not check all the inputs and just does the default one when you do the auto-tune search function to find the active channels. Also, check to see that your wall receptacle is actually hooked into your active cable TV line. You should have a splitter somewhere in the same line that your other TV is using. If not, that jack that you are hooking up your new TV to is probably not active.
Sharp Aquos... | Answered on Jan 01, 2018
Did any of this suggestions work? I'm having exactly the same issue over here, I did the "remove the batteries and touch all the buttons" thing and nothing, I guess I'll have to carry out the more technical procedures
Sharp Aquos... | Answered on Sep 19, 2017
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Sharp Aquos... | Answered on Jul 10, 2017
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Sharp Aquos... | Answered on Jun 08, 2017
We have the same problem with our 32" Aquos. Turn on the TV and after a couple seconds the picture goes out but still have audio. So this solution doesn't permanently fix the problem, but it works instantly to get the picture back. With the TV turned off, tap the side of the set twice with the palm of your hand. Turn the TV back on, and VOILA, you have a picture. I know the last thing you think to do is to hit your TV to fix it, but that is often how my husband tries to fix things...this time it worked!!
Sharp Aquos... | Answered on Mar 14, 2017
As long as the tv is not unplugged it should stay on the same channel when turned back on. If you have the tv plugged into the cable box, when the box is shut off it basically unplugs your tv and the tvs memory is reset. The tv should be plugged in to its own outlet or leave the cable box on and turn off the tv. If you turn everything on, cable box and tv, and have a picture, go into the tv menu and auto program the channels, it should only lock in on channel 4 since it will be the only channel the tv will receive.
Sharp Aquos... | Answered on Dec 03, 2016
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Sharp Aquos... | Answered on Oct 23, 2016
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board
Sharp Aquos... | Answered on Sep 05, 2016
From page 8 of the manual:
The POWER indicator on the AQUOS television should light GREEN indicating you have power to the AQUOS television.
If the POWER indicator on the AQUOS television still does not light up, press TV POWER on the remote control to turn the power on.
IMPORTANT:
IF THE UNIT DOES NOT POWER ON - UNPLUG THE AQUOS TELEVISION FROM THE OUTLET AND REPEAT THE INSTALLATION STEPS.
IF YOU STILL ENCOUNTER NO POWER, PLEASE CONTACT US AT 1-800-BE-SHARP
http://www.nemsworld.com/theater/LC46_52D62U_Manual.pdf
Sharp Aquos... | Answered on Jul 02, 2016
Phone Sharp customer care, they will guide you trough the process.
Sharp Aquos... | Answered on Apr 06, 2016
Re scan your channels through the setup.
Sharp Aquos... | Answered on Mar 03, 2016
Sharp Aquos LC-46D62U 46 in. LCD HDTV Logo
454 questions posted
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
Aquos Sharp
  • Aquos Sharp
Most Popular Question
aquios lc 42d64u suddenly
  • Televison & Video
