What you want to check is the lid switch..remove the front panel..on the switch/lid lock asm.will be
the main switch which is part in the black body of the lock asm. the 2 terminals their will have contunuty with zero ohms when lid is closed
when lid closed the white switch will be open and closed when lid open
the one in the black body on the main lock asm. will be open when lid open
IF it does turn out that the lid lock is the problem the part number for it is 134101800
it could be purchased online at;
repairclinic.com
apdepot.com
apwagner.com
searspartsdirect.com
midwestapplianceparts.com
If the switch checks to be good test for power into the drain pump if no power the timer is what is wrong the washer (not dryer) timer is part# 131758600
Gene
