SOURCE: maytag french door frig - Freezer works, frig warm
sounds like the freezer fan motor is worn out
SOURCE: Refrigerator doesn't cool/freeze - clicking, cyclying noise repeates, but doesn't cool
I've been told by a tech who repaired my MFD2560HEQ this past week that many of this model had a problem with compressor failure. Your symptoms are classic. What you are hearing is the starter relay trying to start a warm/hot compressor by supplying it with an extra jolt of electricity, but because of the faulty compressor (or if you are lucky a faulty relay) that's warm (cool ones start more easily often) is refusing to budge into motion and compress the freon. Maytag, I believe, has a five year warranty on the compressors. They did on mine, but unless you have an extended warranty the labor replacing it is not covered and that will be around 2-3 hours worth. This is the price we are paying for our quest for energy efficiency. Compressors are being built so small and light that they fail much more often than grandma's old, old refrigerator that was built like Fort Knox and ran for 45 years, remember? But we're being energy efficient! Thank you environmental extremists! I wish I could send you the repair bill.
SOURCE: Refrigerator and freezer are warm
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
SOURCE: My fridge/freezer will periodically stop cooling.
Lets see if you have a defective defrost timer Click Here=> MTB2176HR Control Panel item number 15 is the defrost timer and should have a hole below it entering the fresh food compartment. Sometimes there is a plastic plug covering hole to hide its opening. Pry plug away and use a flathead screwdriver to turn timer clockwise until compressor either stops or starts. If the compressor stops leave like this for up to 30 minutes. This should be manual defrost. and if it does not come out of defrost gently turn timer again slowly until compressor restarts. If you need to do this the timer will need replaced. Part number=> 68233-3 Look into the rear of the freezer compartment and you see frost building on the rear freezer wall I believe you are not defrosting until your defect defrost time finally drags around to defrost. Now if this is not the case I need you to tell me ASAP because I will have a change in plans, Let me know HERE or here on Fixya, I really have the tools, manuals and can solve this for you, Let me know, Thanks Sea Breeze
SOURCE: I have a Maytag French
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Check cold control (thats where you turn it colder)
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME If this was helpful
