SOURCE: loss of bass frequencies in dynamic mics
That's one correct assumption, but it's actually the element that gets damages causing the coil to rub. Open the top up and see if there is any damage, sung a magnifying glass as the tiniest crack could go un-noticed by the naked eye.
In testing these 2 did you change the frequency at all? trying with a different receiver, having another mic on the "bad" mics frequency?
Loss of lows can also be a sign of a bad wire as this sometimes tend to act as a high pass filter.
Did you do the obvious, change batteries?
jeff
SOURCE: need the wiring diagram for a audio-technica
I believe on the 4 pin connector of the pack, pin 1 is shield/ground and pin 2 is low impedance input. One of the other pins is bias voltage and the other is high impedance.
In the UNIT I had, there was a connection diagram someplace in the battery compartment, either on the cover or the case. As I recall it had poor conrast to read and find it so check closely.
SOURCE: I have a audio-technica ATW-T51 and need to
to a web site called parts express.com you will find anything in audio related items there..
SOURCE: changing frequencies on wirleless microphone
want to change the frequency on an Audio Technica ATW252. How do i go about doing it?
