20 Most Recent Audio Technica AT-LP2D Turntable Questions & Answers
this is belt driven turntable....have you tried adjusting it via the pitch control or even getting another belt for that turntable....
Audio Technica... | Answered on Jan 03, 2015
Plug it into the wall socket...Duh!!
Audio Technica... | Answered on Dec 23, 2014
Hi, most likely the belt has come off or needs replacing. Remove the platter and check. Cheers john. Stylus City
Audio Technica... | Answered on Apr 05, 2014
First off, is this a Sony or an Audio Technica? There can be many mechanical issues causing this. For more information, or should you have any further questions, please visit my website at audioserviceclinic.com. You may contact me through the website. Thank you
Audio Technica... | Answered on Dec 17, 2013
there is an on line site where i get all my electronics from Vintage
Electronics very easy to find what u r looking for
Audio Technica... | Answered on Oct 02, 2013
Try to lift the table (it might have a "c" clip lock in the center) and check the belt or idler tire on the bottom of the table.
Audio Technica... | Answered on Feb 07, 2011
hi, you need first a pre amp phono or mixer before you patch into the computer to amplified signal in to your vinyl..
Audio Technica... | Answered on Jul 09, 2009
Mine had the same problem. It was under warranty and Audio-Technica replaced it promptly.
Audio Technica... | Answered on Jun 20, 2009
Try cleaning that lp with an anti static felt record brush, and look for either groove glide or d4 cleaner....Sounds odd, but ive ad records kept in tip top, climate controlled, and funk still gets in the groove.
Audio Technica... | Answered on Oct 29, 2007
If it is UHF and fairly new, select the frequency on the transmitter and then power up the receiver, press search and it should find it.
Audio Technica... | Answered on Jul 14, 2018
Use an alternative device connected to the input the turntable usually connects to. If both channels work ok the new turntable is clearly faulty and should be returned under warranty.
Audio Technica... | Answered on Mar 05, 2018
Audio Technica AT-LP2D Turntable Logo
17 questions posted
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
GFXTech
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Audio Technica Audio Players & Recorders
Most Popular Question
turntable spins fast both speeds
  • Audio Players & Recorders
