20 Most Recent Audio Technica AudioTechnica ATLP60USB LPtoDigital Turntable w USB Output Questions & Answers
hey there Jack, I have the exact same turntable and had the exact same problem. It's a pretty simple fix.
The control arm for the stop button,more then likely, got pushed a bit too far back.
Now bare with me, because I don't know the names of the mechanisms, but I'll try to make it sound simple.
First you're going to take off plate and belt, because you're going to be taking off the bottom cover of your turntable. If you don't remove the plate & belt, when you flip over the turntable, it's all going to fall and you could damage your belt.
Next your going to flip over the turntable and remove the screws that are holding on the bottom cover on. I think there are 5 of them.
Now that the cover is off, look at where the play and stop buttons are. Follow the thin metal arms that are connected to them. They should end at a white plastic piece (sorry, I don't know the name of it). Now check if the stop arm is hooked behind it or if it's pressed against the front of it. The stop arm should be RESTING ON THE FRONT of the white plastic piece.
If it's hooked behind the plastic piece, carefully pull it out and then place it against the front of the white plastic piece and you should be good to go.
Audio Technica... | Answered on Jan 05, 2020
If it is UHF and fairly new, select the frequency on the transmitter and then power up the receiver, press search and it should find it.
Audio Technica... | Answered on Jul 14, 2018
Use an alternative device connected to the input the turntable usually connects to. If both channels work ok the new turntable is clearly faulty and should be returned under warranty.
Audio Technica... | Answered on Mar 05, 2018
please give me equalizer code vodafone 543
Audio Technica... | Answered on Mar 28, 2017
You should go back to the local repair shop and ask them to do the job right or to give you the money back you presumably paid. You have a legal right to have them fixed properly.
Audio Technica... | Answered on Feb 10, 2017
If you have replaced the cartridge then it must be the cartridge pre-amp that is faulty. If there are any other functions on the device such as CD, then it will not effect them. Unless there is crackling on any other function then the pre-amp has a problem. The pre-amp itself is generally a single IC. You can find it by following the turntable connection back to the inside of the amp. The signals will pass through the IC before being passed to the main pre-amp.
Audio Technica... | Answered on Jul 28, 2016
Having looked at the turntable it seems to mount the cartridge with two bolt like fittings. The Cartridge you want has two mounts on the side that will take those bolts.
You will have to adjust the arm to compensate for the weight differences between the two cartridges, but once done it should play fine.
I have used this article to set up my dual turntable.
Cartridge Alignment The Basics Explained
Tracking force: 1.5 to 2.5g
Your cartridge specifications are in the following link.
Audio Technica AT91
Hope this helps?
Audio Technica... | Answered on Mar 23, 2016
quite likely there is no way as 78's are OLD .
Audio Technica... | Answered on Sep 17, 2015
Normally, yes. If you'\'re not sure how to track down the part that's broken, contact the maker for an ra to return it for service.
Audio Technica... | Answered on Jun 19, 2015
This is the only thing I could find online:
1 - shield
2 - left (hot)
3 - left
4 - right (hot)
5 - right
Audio Technica... | Answered on Apr 13, 2015
Audio Technica AudioTechnica ATLP60USB LPtoDigital Turntable w USB Output Logo
Popular Tags
3 questions posted
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
GFXTech
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Audio Technica Audio Players & Recorders
Most Popular Question
stop button record player doesnt stop
  • Audio Players & Recorders
