20 Most Recent Audio Technica ATW-T52 Professional Microphone Questions & Answers
Audio Technica Part number 235401550, call 330-686-2600. The cost is $21.93, plus shipping
Audio Technica... | Answered on Oct 26, 2013
I have the same problem in my ATW T52, in st by its ok (the rf leds show perfect signal) but when i set in on the af level start punch and i hear in the monitor a noise like a heartbeat (pum-pum-pum....) Please any answer for this problem
German
Radio del Sol 96.3 Mhz
Villa de Merlo - San Luis
Argentina
Audio Technica... | Answered on Sep 19, 2011
A common problem that SOME have is due to the foam windscreen inside the metal screen rubbing the diaphram of the mic.
Unscfew the dome screen and make sure the foam is out agaist the scree everywhere.
If the dome has become dented, this is my cure: Temporarily remove the foam sheet inside the dome. Put the dome over the handle of a Crescent wrench (has about the right contour). Pound on the screen with a RUBBER mallet, rotating the screen as it reforms! Good as new! Replace the foam sheet and reassemble!
Audio Technica... | Answered on Dec 26, 2009
The problem could be either your mic or the reciever, if all of the mic that was connecting to the receiver was not functioning the problem could be on the receiver. but if only one unit(mic) has not working this can only be the mic or the transmitter with it..
Hope this helps
Audio Technica... | Answered on Sep 06, 2009
Some of these have a body cover that just unscrews off, and expose a set of rotary channel and group selector that you can turn with a small flat screw driver. Match to the new numbers letters on the receiver. If it is the LED type you just need to hold the ch or grp button down until the display flashes then just toggle through the codes.
Audio Technica... | Answered on Jul 27, 2009
It is very common to have the squelch on the receiver set at full or much too high. With the audio output unplugged or at least turned all the way down, and with the transmitter turned off, locate the squelch control - you may need a screwdriver depending on which model of receiver you have. Turn the squelch control counter-clockwise until the TX light turns on, then turn it back up just past the point where it turns back off.
If you turn it all the way down and the TX light doesn't come on, that's okay. If you get blasts of noise occasionally when the transmitter is turned off, then set the squelch a little (only a little) higher until it stops.
Joe
Audio Technica... | Answered on Jul 23, 2008
If it is UHF and fairly new, select the frequency on the transmitter and then power up the receiver, press search and it should find it.
Audio Technica... | Answered on Jul 14, 2018
Audio Technica ATW-T52 Professional Microphone Logo
Popular Tags
19 questions posted
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
GFXTech
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Audio Technica Audio Players & Recorders
Most Popular Question
help
  • Audio Players & Recorders
