Question about Audio Technica AT-PL120 Turntable
At-lp120-usb turntable. power is on- start button pressed but not turning- no click sound when start button is pushed
    Champion:
    New Friend:
  • 215 Answers
Replace button
Posted on Dec 23, 2014
2 Suggested Answers
alicantecoli
Colin Stickland
  • 22485 Answers
SOURCE: i have a, at-lp120-usb audio technica turntable
i think it has lost the drivers or something so i would just re-install it ,unplug the usb cable then turn computer off then restart computer and then when windows has fully loaded plug the usb lead back in and it should find a new devie and install drivers for it and it will search it memory for drivers ,find them and re-install them and off you go again ,computers are funny thing and often have a brain storm .
Posted on Nov 26, 2010
gfbe
  • 6 Answers
SOURCE: Turntable turns on, but when "start" button is
Pull the aluminum record platter where the record sit on and check to see if the belt off. If it is broke you may need a new one.
Posted on Dec 02, 2010
When connecting AT-LP120 Audio technica turntable to Onkyo stereo receiver TX-8140 I get distorted sound - the turntable came with set cables installed to connect. How do I resolve this problem
hi,
instead of plugging your turntable into "phono in" on the amp just try a regular auxilary input like aux ,video, or cd. sounds like the turntable output isnt like the old ones and may be just a regular output.
Sep 29, 2018 | Onkyo Audio Players & Recorders
When I push start button turntable doesn't rotate
Technics SL-QD33 doesn't turn - Vinyl Engine
www.vinylengine.com/turntable_forum/viewtopic.php?t=28381
Jun 3, 2010 - 15 posts - ‎3 authors
It powers up, lights come on but the platter won't spin. ... However when I press "start", nothing happens and the platter won't spin when ... the arm towards the record without pressing the "start" button. ... SL 7, SL-10... and / or any of the fully automatic Technics turntables using optical record detection......etc Marantz 6300 question...
Nov 21, 2009
Dual CS505 turntable won't auto-start
Aug 16, 2009
More results from www.vinylengine.com
Help!! My Turntable won't spin - AVS Forum ' Home Theater ...
www.avsforum.com/.../1316271-help-my-turntable-won-t-spin.html
18 posts - ‎7 authors
Dec 21, 2015 | Audio Players & Recorders
I just purchased the AT-LP120-USB - it's was a beast to get the thing balanced correctly, but now i hear some very obvious crackling sounds that weren't there before when the tone arm wasn't...
as long as you have balanced your tonearm correctly, maybe its simply just a problem with your vinyl? could just be dust in the grooves or could be static build up, try cleaning your vinyl with an antistatic cloth to see if the sound improves.
May 05, 2011 | Audio Technica AT-PL120 Turntable
I received a new Sony Turntable PS-LX250 as a gift. I followed the instructions for installing it to my system, but it doesn't work. Nothing happens when I push the start button. Any suggestions for...
Hello
Check whether the drive belt is in position. If it has slipped out of the motor pulley, turn table won't turn when you push start button. Mke sure that power chord is connected firmly and the power does comes to the player. If drive belt is deteriorated replace it.
There is no other special faults to occur to the player. You have the manual and refer to its fittings. OK.
Jan 23, 2011 | Sony PS-LX250H Turntable
Dec 02, 2010 | Audio Technica AT-PL120 Turntable
Will not turn on
With the power cord getting hot it sounds like there is something up with the power supply section. Perhaps a faulty transformer or something.
Sep 18, 2009 | Aiwa PX-E860 Turntable
Projector won't power up
the colorwheel is going. time to replace.
Jun 18, 2009 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Help
Lift up the platter underneath should be a belt (black rubberband) on the platter. Once you find it leave it there put the platter back on, pad off. With the player off put the belt over the brass motor spindle.
Dec 21, 2007 | Gem Sound DJ-2100 Turntable
Audio Technica AT-PL120 Turntable Logo
1,605 people viewed this question
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
GFXTech
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
