Question about Audio Technica Audio-Technica ATW-T701 Microphone
Microphone cutting out during use
Our mic cuts out when in use during our church service. How do I fix it?
Posted by Eric Norris on
Stefan Mayrhofer
    New Friend:
  • 40 Answers
Reduce distance between receiver and transceiver (microphone)
Adjust antennas not parallel.
Posted on Apr 24, 2014
Have wireless mic that when turned on and you are talking into mic cuts out the music. How can I fix it so that the music stays on and I can voice over??
This is dependent on the mixer that you are plugging the music and microphone into. This is usually called "Ducking". Contact the mixer manufacturer to find out how to turn off the "ducking" feature.
2answers
Microphone cutting off
Ensure the battery in the mic is 100% - low batteries can cause all sorts of symptoms. I wouldn't recommend anything other than a well known brand of Alkaline battery and definatley not rechanrgables.
We have a problem with what sounds like the mic.
There are so many variables with sound systems, sometimes it's hard to isolate the problem. When I have a problem with the sound system at my church I usually try and force the problem again. In my experience it's usually been the cable that will go bad before the microphone. Try moving the cable around at the end where it plugs into the microphone, if you get any crackling or popping it usually means the cable has a short in it somewhere. Another problem I run into pretty often is that the channel on the soundboard is having problems. Try switching channels and see if the problem comes up again.
When push lead in it works then peaks really loud and cuts out why please
This mic will need to be serviced, as mostly likely one or more components have failed. Condenser Microphone Mod Service
1helpful
The countryman E6 mic caused a loud bang during use.
It appears that the "bang" was the result of a static discharge from the mic boom. I trust it doesn't happen again.
Microphone cuts out
If you tried other cords and other PAs the problem might be in the jack where the cord plugs into the mike. [email protected] might also be able to give you more info.
Shure wireless UHF microphone
Make sure the microphone and the receiver are still broadcasting/receiving on the same channel.
Check that all of the appropriate connections are right from the receiver to the mixing board are connected as well.
I hope this helps!
God Bless you!
Audio Technica Audio-Technica ATW-T701 Microphone Logo
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
