If your turntable has an stereo output through it RCA output connector make sure that the RCA cord you are using is new means there is no cut of wires inside it .check the continuity by connecting the RCA cord to the auxiliary input of your reciever then touch the plug with your hand.you should hear a loud humming audio left and right following which plug you are touching.it means the cord is good.if only one channel you hear then replace the cord.good luck..
