Hi a_rappaport,
If you want to restore the factory defaults, please follow the steps below.
Note: All current configuration will be deleted, including your password. Restoring factory defaults does not change or delete the Tenor's IP address, subnet mask or default gateway; you will still be able to communicate with the unit after a reset. You can set all system configuration settings back to their factory defaults through the Command Line Interface (CLI) as follows:
1. Access the CLI through a Telnet session. See the Command Line Interface (CLI) guide for more information.
2. Access the Config-VOIPNetwork-1 prompt.
3. Type setfactory. You will be asked if you are sure you want to set the unit back to factory defaults.
4. Type yes to confirm (type no to cancel the restore).
Reset System
The Reset system feature enables you to reset the system, including hardware and software. You can reset the system through the unit's Back Panel or through the Command Line Interface (CLI). Back Panel. Use a blunt, thin object to press in the Reset button, located on Tenor AX's front panel. The system will reset. Command Line Interface (CLI). You can reset the system through the Command Line Interface (CLI) as follows:
2. Access the Maintain-MasterChassis-1# prompt.
3. Type reset. You will be asked if you are sure you want to set the unit back to factory defaults.
Through this simple Command Line Interface (CLI) telnet
session, you can access all configuration options, including an online help system, built into the CLI, which provides help for all features and functions. Just type help at any prompt, and data about that field will be displayed.
Hope it helps.
Thank you for using FixYa.
