20 Most Recent
D-Link Express EtherNetwork DI-604 Router Questions & Answers
Nortel Contivity VPN client?
Nortel Contivity will work with the your D-Link router, however its functionality depends on the authentication type (AH will not work), NAT compatibilty mode, and disabling keep alives on the server. Contact your Network Administrator to find out how your VPN is configured.
Step 1 Verify that you are using the latest version of firmware on your router.
Step 2 Login to the Web Management for your router by entering its IP address (192.168.0.1) in your web browser. The default username is admin, and the password is blank.
Step 3 Click the Advanced Tab to access the Virtual Server Settings. There is a list of pre-defined Virtual Server Rules towards the bottom of the page. Find the IPSec Rule. Click the pen and paper icon to edit its settings. Enable the rule, enter the IP address of the computer attempting to connect to the VPN in the Private IP field, then Apply the changes.
Step 4 Create a new Virtual Server entry. Name the Virtual Server, "NortelVPN". Enter the IP address of the computer attempting to connect to the VPN in the Private IP field. For the Protocol Type, select Both. Enter 9550 for both the Public and Private Ports. Set the Schedule to always, then Apply the settings.
Step 5 Access the Tools Page, then click the Misc button. Disable IPSec Pass-through, then click Apply.
If the VPN Server is properly configured to work with clients behind NAT routers you should be able to connect to the VPN.
Setting up a wireless
You will have to turn on the DHCP in your router's settiings. Once it is turned on all the devices connecting to it will automatically receive the IP address.
Hello!. The day before I
I am not familiar with this router but there is usually a reset button on it which puts it right again. Do you have a manual?
Otherwise go online to the supplier of the modem.
How do I configure UPnP? on my router?
Universal Plug and Play (UPnP) allows discovery of UPnP enabled devices in a network environment. UPnP is only available on Windows Me and XP. If you are not using either operating system on any of your computers, or do not want to use UPnP, then it is recommended to disable UPnP on the router.
Step 1 Open a web browser and type the IP address of the wireless router in the address bar (default is 192.168.0.1). Press Enter.
Step 2 The default username is admin (all lower case) and the default password is blank (nothing). Click OK.
Step 3 Click the Tools tab then click Misc. to the left.
Step 4 Under the UPnP Settings section, select Enabled using the radio buttons to enable UPnP on the wireless router, or select Disabled using the radio buttons to disable it.
Step 5 Click Apply and then click Continue to save the new settings.
Reset to factory settings??
Step 1 With the unit on, place a paper clip into the hole on the back on the unit labeled Reset.
Step 2 Hold paper clip down for 10 seconds and release.
Note: Do not repower unit during this procedure.
Step 3 The unit will reboot on its own. Once the WLAN light stops blinking, the unit is reset.
Resetting the router does not reset the firmware to an earlier version. It will change all settings back to factory defaults.
Factory default
The following reset procedure will completely restore the default settings on the VDI-604 and VDI-624.
Note: If you do not remember your password, you will have to reset the router to factory defaults.
Step 1 Locate the reset pinhole on the back of the unit.
Step 2 With the unit powered on, press and hold the Reset button.
Step 3 Hold the Reset button for about 10 seconds.
Step 4 Release the Reset button.
Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting.
Step 6 The device is now at factory defaults.
Note: Do not recycle power during the reset procedure.
VDI-604 firmware 1.05F/VDI-624 firmware 2.39DDM - The default username is admin and the default password is blank (nothing).
VDI-604 firmware 1.07 Build 28/VDI-624 firmware 2.43 Build 12 - The default username is admin and the default password is password.
Note: After resetting the router to factory defaults, you will need to contact Verizon to reconfigure your WAN settings.
What changes have been done to the latest firmware for my DI-604 and DI-614+?
V3.36 (DI-604 RevE only):
Fixed minor interface bugs
V3.38 (DI-604 RevE only):
Fixed issue with non-standard FTP port function
Fixed issue with WAN speed selection feature
Fixed issue with Stats page - showing 0 transmitted packets
Fixed minor Virtual Server bug
V3.39 (DI-604 RevE only):
Add WAN speed selection option - defaults to 10Mbps
Fixed dial on demand/idle time bug
Fixed Asheron´s Call II reboot issue
Fixed Static DHCP/MAC filter clone issue
Fixed Virtual Server entry bug
I have dlink di-604,,the prob.is
This looks like the firmware has failed on the unit as a firmware reset displays 1-4 flashing.
You can try holding the reset in while powered on for 10 sec, failing that it would be cheaper to replace the unit. You can pick up cheap routers from a company called TP-Link which are ok.
Hope this helps!
When i connect the di-604
Connect the router to your computer and modem.
Open Internet Explorer and in the address bar go to 192.168.0.1
Username=admin and leave password blank.
Click on run wizard and follow the steps.
hope this helps
I need the password to set up my second computer
Two options:
Since you cannot get a crash course in hacking Wifi networks, then you can either:
1) Reset your router's password by connecting a computer using a LAN connection (Wired) and choosing a new password (This is of course if you know the admin user and password).
2) If you don't know the Admin password then you have a button at the back of the router that is used to reset it. Press it for 10 seconds. NOT TOO HARD, it is hanging on a small hinge so if you press it too hard you will break it and then you will need to open the router...
after reseting your router, enter address
http://192.168.1.2 on Internet Explorer and follow the Setup instructions.
Good luck.
How do you dis-able gaming mode feature?
Log into your router.
-> Open the "Tools" tab
-> Click on the "Misc." button on the left size.
You will see the opion to disable the "Gaming Mode" the 5th one down. The color is a bit faded blue but you can see it just under "UPNP Settings".
-> Mark it on "Disabled" then hit "Apply" at the buttom of the page.
I usually recomment "Reboot" after you clicked "Apply". (Button at the top of the same page you are on).
Good luck.
Nothing connects from the router online pluged the
Check ur cable between modem and pc. Ensure that led glows on ur LAN port of pc. Then from pc, try to ping router's ip address.
Ex: ping 192.168.1.1
If u receive response from the router, then the connection is fine.
Else there might some problem on ur router. Replace the router and try again.
I have connected my DI-104 Router to my Motorola
Turn the router off.
Use an Ethernet cable to connect one computer to one of the 4 'LAN' ports on the computer.
Turn the router on.
Click Start
Click Run
Type CMD
Press ENTER
Enter IPCONFIG /RENEW
Press ENTER
Look for lines of output like:
IP Address. . . . . . . . . . . . : 192.168.40.150
Default Gateway . . . . . . . . . : 192.168.40.1
Open Internet Explorer.
Enter:
http://192.168.40.1 (if that's the IP-address on your computer for the 'Default Gateway').
You should see a D-LINK "login" web-page.
Try an ID of 'admin' and a 'blank" password.
Once logged-in, you can check the router-settings, and then "configure" it.
