20 Most Recent D-Link AirPlus Xtreme Super-G DI-624 Wireless Router (di-624/b) Questions & Answers
The following reset procedure will completely restore the default settings on the VDI-604 and VDI-624. Note: If you do not remember your password, you will have to reset the router to factory defaults. Step 1 Locate the reset pinhole on the back of the unit. Step 2 With the unit powered on, press and hold the Reset button. Step 3 Hold the Reset button for about 10 seconds. Step 4 Release the Reset button. Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting. Step 6 The device is now at factory defaults. Note: Do not recycle power during the reset procedure. VDI-604 firmware 1.05F/VDI-624 firmware 2.39DDM - The default username is admin and the default password is blank (nothing). VDI-604 firmware 1.07 Build 28/VDI-624 firmware 2.43 Build 12 - The default username is admin and the default password is password. Note: After resetting the router to factory defaults, you will need to contact Verizon to reconfigure your WAN settings.
D-Link AirPlus... • Answered on Oct 23, 2012
The router can be installed without the CD. If you are experiencing any problems, you can reset the router to factory default settings, press the reset button at the back of the router.
Please note that after RESETTING THE ROUTER to defaults, ALL SETTINGS WILL BE LOST AND YOU HAVE TO RECONFIGURE IT. Generally, after hard reset you get the connectivity, however, you have to make the connection secure etc.
Reset the router to factory default setting, press and hold the reset button for few seconds (It is at the back of the router near the DC Power Jack). The LEDs will then blink and the routers factory settings would be restored. Please note that, after resetting the router you should be able to see the router and connect to it via LAN Cable or Wirelessly as the router automatic assigns the IP Address and gateway etc. Before proceeding to the next step please make sure that you are getting the signals as well as internet. However, the internet connection would not be secure, which can be done later.
Now, all you have to do is connect to the router and secure the connection follow the following steps: -
First you have to access the router through web browser (Internet Explorer) by typing the IP address of your router in the address bar, which is 192.168.0.1 (Default router settings are written under the router)
(unless you've configured otherwise, the default username is admin and the password "leave it blank") and lookup for the options to do the following: -
1. Change the SSID (Name) of the router
2. Change the default administrative user name and password
(The above step would prevent unauthorized access to your router)
Next step is to secure it:
1.On the left-hand side, under Setup, click "Wireless Setup" 2.Under "Wireless Security Mode", select your desired encryption method (preferably WPA2-PSK)
3.Choose a Network Key - it can be anything, as long as it's 8-63 characters in length
4. Click Save Settings.
Now your router and your connection would become secure and the user has to provide the network key to access the internet.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
D-Link AirPlus... • Answered on Jun 06, 2011
This is NO software as such as it is all built into the router, simply access router properties by typing the router address (192.168.0.1) into the browser.
D-Link AirPlus... • Answered on Jan 07, 2010
Click here the setup of the dlink router are compatible to any brand. Download the quick router setup 4.00 then install it to the computer.
D-Link AirPlus... • Answered on Mar 24, 2009
When you reset a router, it restore its settings to factory-default. If you are attempting to log in to the router's control panel, you will now have to use the factory default login credentials.
These credentials are:
Login: admin
Password: admin
Let me know if I can assist you further, or if I need to explain any of what I mentioned above in more detail.
If you found my solution to be helpful, or if it resolves your issue, please rate the solution.
D-Link AirPlus... • Answered on Mar 23, 2009
If that is status of the lights on your router there's a big possibility that its already bad and needs a replacement, but you can first try to reset it and check if that will correct the problem
, To reset the router just press and hold the reset button for 30 seconds while the power is ON then after that check if the lights are back to normal if still the same light router is already bad...
D-Link AirPlus... • Answered on Dec 01, 2008
Step 1 Download the latest firmware. Click here to download the latest firmware for the VDI-604 - http://support.dlink.com/products/view.asp?productid=VDI-604#firm Click here to download the latest firmware for the VDI-624 - http://support.dlink.com/products/view.asp?productid=VDI-624#firm Step 2 Open a web browser and type the IP address of the VDI-604 or VDI-624 in the address bar (default is 192.168.0.1). Press Enter. Step 3 The default username and password is listed below for your version of firmware: VDI-604 firmware 1.05F/VDI-624 firmware 2.39DDM - The default username is admin and the default password is blank (nothing). VDI-604 firmware 1.07 Build 28/VDI-624 firmware 2.43 Build 12 - The default username is admin and the default password is password. Click OK. Step 4 Click on the Tools tab at the top and then click Firmware on the left side. Step 5 Click Browse and navigate to the .bin file you downloaded in Step 1. Select the file and then click Open. Step 6 Click Apply. It may take a up to 30 seconds for the firmware upgrade to complete. Step 7 When prompted click Continue. The firmware upgrade is now completed. Step 8 If you get a Page cannot be displayed or similar error after clicking Continue, close the web browser and re-open it. Repeat Step 2 to login to the web-based configuration.
D-Link AirPlus... • Answered on Jan 19, 2008
try this link: http://www.freedom.net/support/bug.html
D-Link AirPlus... • Answered on Feb 16, 2006
The WAN settings should be configured by Verizon personnel only. If you reset the VDI-604 or VDI-624 to factory defaults, you will need to contact Verizon to reconfigure your WAN settings.
Step 1 You will need the IP address of the computer that you want to open ports to. How do I find the IP address of my computer? Step 2 Open a web browser and type the IP address of the VDI-604 or VDI-624 in the address bar (default is 192.168.0.1). Press Enter. Step 3 The default username and password is listed below for your version of firmware: VDI-604 firmware 1.05F/VDI-624 firmware 2.39DDM - The default username is admin and the default password is blank (nothing). VDI-604 firmware 1.07 Build 28/VDI-624 firmware 2.43 Build 12 - The default username is admin and the default password is password. Click OK. Step 4 Click the Advanced tab at the top and then click Firewall on the left. Step 5 Select Enabled and configure the following: Name - Enter a name to identify the rule Action - Select Allow Source Interface - Select WAN Source IP Range Start - Enter an IP address or * to allow this rule to apply to all incoming IP addresses. If you are opening this rule to a series of IP addresses, enter the first IP address in the range. Source IP Range End - If you are opening this rule to a series of IP addresses, enter the last IP address in the range. Destination Interface - Select LAN Destination IP Range Start - Enter the IP address that you obtained in Step 1 Protocol - Select the protocol (TCP, UDP, or Both) Port Range - Enter the starting and ending ports that you want to open Schedule - Select Always to apply this rule all the time or Schedule to specify a schedule Step 6 Click Apply and then click Continue to apply the new rule.
The following types of parental control can be configured on the VDI-604/VDI-624: Domain Blocking URL Blocking -------------------------------------------------------------------------------- Domain Blocking Domain Blocking will allow/deny access to certain websites. Step 1 Open a web browser and type the IP address of the VDI-604 or VDI-624 in the address bar (default is 192.168.0.1). Press Enter. Step 2 The default username and password is listed below for your version of firmware: VDI-604 firmware 1.05F/VDI-624 firmware 2.39DDM - The default username is admin and the default password is blank (nothing). VDI-604 firmware 1.07 Build 28/VDI-624 firmware 2.43 Build 12 - The default username is admin and the default password is password. Click OK. Step 3 Click the Advanced tab at the top and then click Parental Control on the left. Step 4 Below Parental Filters, select Domain Blocking. Step 5 Below Domain Blocking, select Allow users to access all domains except "Blocked Domains" to only allow to all websites except those listed or select Deny users to access all domains except "Permitted Domains" to only allow access to the websites listed. Step 6 Enter the website (i.e. disney.com) below the option you selected in Step 5 and then click Apply. -------------------------------------------------------------------------------- URL Blocking URL Blocking will prohibit access to websites than contain certain words. Step 1 Open a web browser and type the IP address of the VDI-604 or VDI-624 in the address bar (default is 192.168.0.1). Press Enter. Step 2 The default username and password is listed below for your version of firmware: VDI-604 firmware 1.05F/VDI-624 firmware 2.39DDM - The default username is admin and the default password is blank (nothing). VDI-604 firmware 1.07 Build 28/VDI-624 firmware 2.43 Build 12 - The default username is admin and the default password is password. Click OK. Step 3 Click the Advanced tab at the top and then click Parental Control on the left. Step 4 Below Parental Filters, select URL Blocking. Step 5 Below URL Blocking, select Enabled, enter the word, and then click Apply.
try changing the channel number from auto to a channel number 2 or 3 higher than the lowest channel number.' do this by logging into the d-link dsl 2640
D-Link Computers... • Answered on Mar 22, 2021
access violation in module Uimain.exe at address oo6F6AB6 read address 000002EC
Computers &... • Answered on Feb 13, 2020
Ethernet/USB Print Server it is for even windows 98 (OMG ) page 7 is setup. NO OS stated by you, at all. why:? page 3 is OS compat. after reset the default address is 192.168.0.10 5volt power pack is NOT OPTIONAL. 1998 what did you read the free manual yet. the last page shows printer compatibility list, does your match? where would you find a printer that old working now. crickets...??? my guess is 2003 year made. XP first release is that. one manual for it stamped 2003 so is 17 years old relic fodder for sure, recycle it is best. first hit https://eu.dlink.com/-/media/consumer_products/dp/dp-300u/datasheet/dp_300u_datasheet_en.pdf RTM ! no 17 year old printer works today, not really.
D-Link Computers... • Answered on Dec 19, 2019
the manual is free , at dlink dot com you push the reset button for long time per manual 15sec (iirc) the release it and now all defaults are set. per the manual, google dir-655 manual. easy as pie if you just read the manual.
D-Link Computers... • Answered on Dec 12, 2019
There's a reset button on the back of the router, it's a small button that you can press using a paper clip. Press it for 15 seconds to reset it.
Reset 1:
Press the reset button for 15 seconds at the back of the router while the router is on.
Reset 2:
Press the reset button for 15 seconds while the router is on after 15 seconds unplug the power cord while holding the reset button then count another 15 seconds and release the reset button. Then plug the power cord back in.
Reset 3:
Press the reset button for 15 seconds while the router is on after 15 seconds unplug the power cord while holding the reset button then count another 15 seconds and plug the power cord back in while the reset button is plugged in and count another 15 seconds release the reset button.
Hope this helps.
D-Link Computers... • Answered on Dec 04, 2019
D-Link AirPlus Xtreme Super-G DI-624 Wireless Router (di-624/b) Logo
Popular Tags
19 questions posted
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
k24674
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • D-Link Computers & Internet
Most Popular Question
upgrade firmware vdi 604 or vdi 624
  • Computers & Internet
