I think your power supply is faulty. There are a number of things that could be causing your power supply not to fire your tv up.
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board. You might be lucky it's just a blow fuse. Also a defective transformer can cause your TV not to power on.
All these can be checked on the power supply board.
But more often bad capacitors causes problem on the power supply board. I do not think the power board needs replacement, rather those defective capacitors is causing this issue. Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored. Or you can by a refurbished complete power board to save you some stress.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Regards.
Your RCA rear projection TV may not turn on from time to time for several reasons. First, check that the power cord is plugged into a working power outlet. Check that the outlet is receiving electricity by plugging a different device into the outlet. If the other device doesn't work, you may need to replace a fuse or reset a circuit breaker in your home.
If you tried using the remote control to turn on the TV, press the "Power" button on the front of the TV. You may have a problem with the remote control if the TV turns on.
If you tried using the front control panels and haven't tried the remote, press the "Power" button on the remote control. The television controls are blocked if the TV turns on with the remote. To unlock the controls, open the "Parental Control" menu and remove the check mark next to "Front Panel Block."
Finally, your TV may be performing a diagnostic check. These checks are used to find any errors in your TV. Wait a few minutes before trying to turn on the TV again.
You may find that your RCA TV turns off by itself on occasion. This is often because the "Sleep Timer" feature was enabled. This feature allows you to place a timer on the television that will turn it off after a specific amount of time has passed. The feature allows you to save on your energy bill and extend the life of your television.
If the "Sleep Timer" wasn't set, the television may have detected a power surge in your home and shut off automatically to protect the components of the television. Wait at least 30 seconds before turning the TV on again.
Finally, if you suspect the television is turning off for a reason other than a power surge, unplug the television and let it sit for at least 10 minutes. This will clear any errors in the television. After 10 minutes, plug the television back into the outlet and resume normal use.
A blank screen on an RCA rear projection television is usually caused by a loose connection or an incorrect setting. Check that the coaxial connection on the back of the television is secure or, if you're using an external device such as a DVD player, the video cables are secure. Press the "Ant/Cable" button to switch between tuners if you are watching television, or the "Input" button to switch between input channels if you're watching something from an external device.
