LG DLE2514 Electric Dryer Logo
Posted on Apr 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We own the LG DLE2514W front loading dryer. Drying clothes no longer efficient. Cleaned the intake at back of dryer and checked for obstructions in exhaust pipe, still not as efficient as a few weeks ago. By the way, we've owned the dryer for 5-6 years with impeccable results. What's the next step?
Tim Whalen
Level 3:
  • Master 3,076 Answers
  • Posted on Apr 17, 2011
Tim Whalen
Master
Level 3:
Answers
3076
Questions
0
Helped
824484
Points
9577
Disconnect the vent tube run dryer with a load of clothes
LG Washer Dryer F1403RD low drying efficiency. Any ideas
If it’s taking a long time to dry, check venting for obstructions or kinks.
Oct 13, 2018 • Dryers
How and where does one clean the filter on a defy autodry? I need to check as there is a warning light which i need to check as it does not want to get warm.
https://www.manualslib.com/manual/926961/Defy-Autodry.html?page=7#manual
Quoting:
Cleaning the Lint Filter
The lint filter, which is located behind
the door, should be cleaned after each
load to maintain optimum drying
efficiency.
The filter and filter cover are located
inside the door surround front.
Insert two fingers into the two large holes
and pull the filter cover free of the door.
Remove the filter mesh and clean off all
the lint by gently rubbing the filter mesh.
Replace the filter mesh and then the
cover.
Ensure that the filter is in position before
closing the door.
Cleaning the rear Air Intake Grille
The air intake grille, at the bottom rear of the machine, should be cleaned regularly to
maintain optimum drying performance.
Remove any obstructions and dust the grille off with a soft brush
Defy autodry Owner Manual Unsuitable Materials
Jul 02, 2018 • Dryers
1helpful
2answers
My LG front loading dryer doesn't dry well
Check the exhaust vent when running and be sure there is a good flow of air. You may have to clean the exhaust pipes all the way through. Dryers require a good flow of air for proper operation.
Jan 10, 2012 • LG Dryers
My LG dryer seems like it is not drying clothes as well. In what used to be a standard amount of drying time, the clothes are still damp. Could the heating element be going out.
I would check your venting to make sure its not clogged. This will cause longer dry times because the dryer cant efficiently remove moisture. Just go outside and feel the air coming out it should be fairly strong, if not the replace or clean your vent line. Good Luck
Mar 13, 2010 • LG Dryers
Lg TROM dryer DLE2514W drying time very slow takes forever
be sure the lint trap is empty, and you might have to check the outside vent for blockage also....it worked for me.
2helpful
2answers
LG DLE2514w electric dryer has loud thud every turn
Most model dryers are supported at thge rear of the drum with a bearing configuration, but usually the front of the drum is supported by some lining pads or guides. These help hold the rotation of the drum concentric. It sounds like your drum is not spinning concentric. My guess would be that some new guides might need to be installed.
Hope this helps...
It takes at least 2 60 minute cycles to dry clothes. Not even 2 years old yet. Not a new problem has always been this way. What is the deal.
Check the blower fan which is mounted underneath the drum on my DLE2514W front loading LG dryer. I experienced poor drying along with a loud thump at the start of each cycle. At first I thought it was a bad roller but later found that the blower fan had separated from its bracket so it was not turning with each turn of the moter but rather spinning freely.
Dryer LG 6DTD3120
You should change it back to regular gas the problem is in pressure reg gas come to your home at much greater pressure then propane that's why it takes longer to dry the other thing is to keep your lint trap clean because it can affect drying once in while blow out lint hose as well
Jul 26, 2008 • Dryers
Maytag dryer
Dear sloika,
I do not believe the problem lies within the dryer unit.
when the dryer unit fails to dry clothes in reasonable time 90% of the time it is the clogged air vent is the reason.
Dryer vent cleaning improves the safety and efficiency of your dryer installation. As dryer vents become filled with lint and other debris, drying time increases and can cause the dryer itself to overheat. This increases energy consumption since the dryer has to run longer to dry your clothes and can also cause fires in the dryer or the dryer duct. The Consumer Product Safety Commission reports dryer related home fires are on the increase.
  • First check your vent hose between the back of dryer and the air outlet on the wall. Vaccum clean the dirty hose and even into the dryer unit using flexable vaccum attachment. also try to vaccum clean airoutlet that goes into your wall as far reach into and much as possible. The dryer's lint filter and its path needs to be cleaned as well.
  • If all air flow path are cleaned it will improve 200% of your drying time.
There is also professional dryer vent cleaners in your area who can help solve the problem. just check your yellowpages..
Feb 16, 2008 • Dryers
Top LG Dryers Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Dryer Expert? Answer questions, earn points and help others
