ASUS RTG32 Router Logo
Posted on Mar 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to reset my username and password. how do i do this?
  • Anonymous Mar 04, 2011
    Hard reset or soft reset?
  • Malin May 09, 2017
    You should call on (( +1-800-585-2494 )) Toll Free Asus and get help for Asus.,
Malin
Level 1:
Habit-Forming:
  • Contributor 14 Answers
  • Posted on May 09, 2017
Malin
Contributor
Level 1:
Habit-Forming:
Answers
14
Questions
0
Helped
16762
Points
77
Anonymous
Level 2:
  • Expert 72 Answers
  • Posted on Mar 04, 2011
Anonymous
Expert
Level 2:
Answers
72
Questions
0
Helped
9248
Points
207
There should be a little pin ***** sized hole on the back. I you hold this in for 10-15 secs it should reset router to factory settings.
Anonymous
Level 2:
New Friend:
  • Expert 35 Answers
Anonymous
Expert
Level 2:
New Friend:
Answers
35
Questions
Helped
7774
Points
109
All wireless routers have a small recessed reset switch located usually on the back. You will probably need a paper clip or pen tip to reach the button. Use the paper clip and hold down the reset switch while the router is powered on for 15 seconds then release the button and power cycle the router. This will reset the router to the setting it came with out of the box. You'll need the default admin password to log onto the config page but that is usually printed somewhere on the router itself or could easily be found with a google search.
2 Related Answers
Anonymous
  • 19 Answers
  • Posted on Nov 27, 2010
SOURCE: need username and password reset
if you are asking to have the router's UI username and password reset and you dont have an access to the rotuer's UI, the only way is to factory reet your router.. however, remember that by doing this, all devices that are currenlty connected to the Internet and wirelessly to your router will get disconnected. You will have to reconfigure the router, everything on it.
For factory reset, push the reset button on the back panel of the router for 1 min using a paper clip, then unplug and replug the power adapter.
Anonymous
  • 1970 Answers
  • Posted on Jun 29, 2010
SOURCE: need default username and password
mcdevito75 here, Best Bet, see your local Staples, Best Buy or any computer store with the info about your router they should be able to help.
3answers
I forgot my username and password Can you please help me? my number is 0435215262
If you are ask router user name or password related then i share a informative links visit and read it.
Forgot router username and password or need to reset router and Linksys Phone Number
Thanks,
Reset password of DGS3627 from console
Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is: 192.168.2.1
Buffalo - Username: root Password: Leave the field blank Default IP address is: 192.168.11.1
D-Link - Username: admin Password: Leave the field blank Default IP address is: 192.168.0.1
Encore - Username: admin Password: admin Default IP address 192.168.1.1
Linksys - Username: admin Password: admin Default IP address 192.168.1.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or 192.168.1.1
TP-Link - Username: admin Password: admin Default IP address 192.168.1.1
TrendNet - Username: admin Password: admin Default IP address 192.168.10.1
Zhone - Username: admin Password: admin Default IP address 192.168.1.1
Zyxel - Username: admin Password: 1234 Default IP address 192.168.10.1
Lynsksy E1200 tried to reset. my passord and network name are of no assistance. After running software, router is not found. Tried using "admin" for both but nothing works. Please advise. ...
2helpful
Forgot my password and cannot reset?
1helpful
Need new password and user
Every company that makes routers etc... has what they call backdoor (default) username and password so if you lost or forgot your username and password there is still a way to get into the router........
so google the backdoor username and password for your router..... and follow these steps
The first step is to reset the router by pressing the reset button on the back......this could be tricky sometimes cause you need something that can reach the button.... the lights will blank if you hard reset is successful .....
Once you reset the router
Step two enter the backdoor username and password....
Simple
........If this does not work .......then hard reset was not successful or you found the wrong backdoor (default) username and password
Please leave a testimony and vote on solution...
Also feel free to ask more questions...
6helpful
2answers
Forgat password
how to change password in grand chase
3helpful
4answers
How to unlock the password
On the back it has a reset button (you may press it with a paperclip). Check the manual for how long you have to keep pressing it restore factory defaults and what will these be exactly (usually admin/password or no password at all).
Lost my key password for belkin g router
there is a small reset button that u will need to push with a pen. Its usually to the back or side of the router.
Just jeep pushing it until the router resets then use the default username and password.
defaults. (normally)
user name - admin
password - admin
username - Admin
password - admin
username Admin
password Admin
user name Admin
password (blank)
username admin
password blank
look in your manual for the default username and password and instructions on how to reset.
Power light red
You need to hard reset the modem. By doing that, unplug the modem from the power outlet. Look at the back of the modem, you will see there a small red button. You need to press that button. You need to get a pin or pen to press that reset button. Press the reset button for 5 mins. Monitor the power light. It will change to orange light and it will restart. Once it restarted, you can release the reset button and wait for the lights to come up. Since you did the hard reset. You need to configure the modem with your username and password from your ISP.
You need to access the gui or firmware of your modem. If it ask for username and password. This is the time you need to contact your ISP. They will help you to configure the modem. Once they provided you the username and password ofr your modem. Write it down so you will have a copy and in case it happen again you know what to do. Username and password for the modem is different from the username and password for your internet. You also need to enter the username and password for the internet so you can use the internet. If you get a red light for the internet, that means the username and password is incorrect.
If this didnt work. You need to replace your modem.
3answers
Hi need to log in my rourter
Open a web browser like internet explorer or Netscape. Enter the ip address of your router in the address bar of your browser.
By default the ip address should be set to 192.168.1.254
type .........http://192.168.1.254
You should see a box prompting you for your username and password. Enter your username and password now. By default both the username and password are blank.
Click the Ok button to log in to your router.
If you already had a password, you need that or need to reset the router to factory settings in order to start over again.
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
