D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B) Logo
Question about D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B)
Reset password of DGS3627 from console
Posted by jayant35 on
Anonymous
    Scholar:
  • 114 Answers
Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is: 192.168.2.1
Buffalo - Username: root Password: Leave the field blank Default IP address is: 192.168.11.1
D-Link - Username: admin Password: Leave the field blank Default IP address is: 192.168.0.1
Encore - Username: admin Password: admin Default IP address 192.168.1.1
Linksys - Username: admin Password: admin Default IP address 192.168.1.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or 192.168.1.1
TP-Link - Username: admin Password: admin Default IP address 192.168.1.1
TrendNet - Username: admin Password: admin Default IP address 192.168.10.1
Zhone - Username: admin Password: admin Default IP address 192.168.1.1
Zyxel - Username: admin Password: 1234 Default IP address 192.168.10.1
Posted on Sep 08, 2011
Reset password
In order to reset the password for the NComputing Administrative Console, you will need to re-install the software and reset the password through the installer. To do this, complete the following:
Launch your NComputing software installer:
  1. The installer will request a password, type anything.
  2. The installer will inform you that the password is wrong, select OK.
  3. You will then be asked if you forgot your password, select Yes.
  4. You will be prompted to restart your installer, select OK.
  5. Your password is now reset; you may Cancel the installation and access your administrative console.
Forgot ps3 password
Please visit the SEN website:
https://account.sonyentertainmentnetwork.com/pc/login.action
At the bottom click "forgot your password" and follow the steps it provides. This will reset your SEN/PSN password across all devices, so once reset the password you set up will be your new PS3 password.
Need to know how to reset my playstation network password
If you have forgotten your PlayStationNetwork password just go to the PSN log-in page, click "Forgot Password" and it will give you two options to reset your password.
My son has reset my password. how can i reset it?
you could answer your security question. then change the password.
16helpful
Wants to reset 3824 3com switch via console
You forget the password for the "admin" user account and can no longer perform important management operations. solution.gif Use the password recovery method outlined below to define a new password for the "admin" user account:
  1. Access the Command Line Interface from the console port and enter the user name "recover" and password "recover" to place the Switch in password recovery mode. The Switch remains in password recovery mode for a maximum of 30 seconds, before it returns to the CLI login prompt.
    note.gif You must use the console port to recover the passsword. If you attempt the recovery method using the network, the password will be rejected.
  2. Perform a hard reset on the Switch whilst it is in password recovery mode by switching it off, waiting a few seconds, and switching it on again.
    note.gif You cannot use a soft reset operation to reset the password of the "admin" user account. This will end the password recovery procedure and return you to the CLI login prompt.
  3. When the Switch has rebooted following the hard reset enter a new password for the "admin" user account.
1helpful
2answers
PS2 portable password reset
to reset the password just select the default setings and will reset the password to 0000
Console and password
I believe you need to contact EMC support and they can provide password recovery/reset firmware. Hope that helps.
Top D-Link Computers & Internet Experts
Mike
Donivan Wise
Narseman
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
