There are multiple components that can cause this.
Open the door and put your finger in the ice tray. Is there any ice or water in it.
If so then the problem is likely the ice maker.
If not then the water supply is either stopped up or the water valve solenoid is broke.
If their is ice then the ice maker may not be making ice for other reasons. Is the Ice Level arm down? If so, the Icemaker has a clock like motor that is actuated by a temperature sensor.
Ice maker calls for water, solenoid fills ice tray, temperature sensor gets cold over about 45 minutes and closes the motor circuit telling the icemaker to dump ice.
If everything is right and still doensn't make ice, some mechanical aspect or the icemaker appears to be broken.
Thanks for using FixYa, Good Luck.
