Panasonic Lumix DMC-TZ3 Digital Camera Logo
Posted on Mar 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to charge a panasonic dmc-zs3 camera. I had to buy a new usb cable and I'm unable to charge it when I plug it into the computer and I have also tried to charge it to a wall mount charger. Do I need to have the camera on a certain setting? Need help, Thanks, Dan
Dou dou
Level 3:
Master:
  • Master 340 Answers
  • Posted on Mar 02, 2011
Dou dou
Master
Level 3:
Master:
Answers
340
Questions
0
Helped
55308
Points
1116
It seems Panasonic dmc-zs3 seems don't support charging the panasonic battery when pluging in computer by USB, Maybe you can find a USB adapter charger, or using a special charger for it.
Where do I load 2 batteries in the digipower rapid charger
Panasonic DMW-BCG10, DMW-BCG10E, DMW-BCG10PP Battery, Technical Specification: Battery Type: Li-ion, Voltage: 3.60V, Capacity: 895mAh. Dimension: 41.60 x 30.40 x 9.40 mm, Product Type: Replacement Battery (Brand New). Compatible with: Panasonic Lumix DMC-TZ10 Series, Panasonic Lumix DMC-TZ18 Series, Panasonic Lumix DMC-TZ20 Series, Panasonic Lumix DMC-ZR1 Series, Panasonic Lumix DMC-ZR3 Series, Panasonic Lumix DMC-ZS1 Series , Panasonic Lumix DMC-ZS10 Series, Panasonic Lumix DMC-ZS3 Series, Panasonic Lumix DMC-ZS8 Series, Panasonic Lumix DMC-ZX1 Series, Panasonic Lumix DMC-ZX3 Series. Panasonic Lumix DMC-TZ22, Panasonic Lumix DMC-TZ6, DMC-TZ8 and Panasonic Lumix DMC-ZS5, DMC-ZS7.
Panasonic DMW-BCG10 Battery
I have a DMC-ZS3 and unable to get my computer to recognize the camera after I downloaded the Lumix software that came with the camera (ArcSoft)
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
I dropped my Lumix DSC ZS3 and now there are
november 23 2010
i dropped my panasonic dmc-zs3 and now there are vertical lines on the view finder. also, these lines appear after taking a photo or video.
can this be repaired?
cost?
thank you in advance ;-(
2answers
1helpful
I have a Panasonic DMC-ZS3 but my child broke the lcd screen, where can I buy one?
HI you can buy it from your nearest panasonic service center or directly from company via net. I like to know your location address then i can gives you a nearest location for buy your LCD screen. Thanks.
2answers
I want a manual of panasonic lumix DMC-TZ7 in
Go to the support section of the Panasonic web site to download a copy.
4helpful
2answers
I just need a user's manual for a Panasonic Lumix DMC-ZS3.
Go here:
http://www.dphotojournal.com/panasonic-lumix-dmc-tz7-zs3-review-samples-user-manual/
And click on the "manual" tab.
In reality, this is trivial to find, if you just type into google:
Panasonic DMC-ZS3 Manual PDF
It pops almost to the top. Probably would have been less effort than putting the question up here ;)
2answers
PANASONIC ZS3 CAMERA
No need to send it to you,
simply type:
Panasonic DMC-ZS3 Specifications
into a search engine.
Panasonic lumix camera fz20eb unable to upload pics to toshiba laptop with windows vista
You should be upload pictures using a USB cable even if you do not have the additional sofware. Once you plugged in your camera, it may take a few minutes for the computer to register a new device and you should be able to view pictures using the Vista popup or in my computer from the "new device"
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
