IF The LIGHT IS FLASHING GREEN then there is something wrong with your wireless network Check your network settings and Retry connecting
Check the adapter's status light
loadTOCNode(2, 'moreinformation');
The adapter's status light can tell you a lot about
the state that the adapter is in. Here's what the different lights
mean:
Steady green light: The adapter is connected to a
wireless router, gateway, or access point. The adapter is ready to use.
Collapse
this imageExpand this image
Steady
red light: The adapter is not recognized. Try plugging the adapter
into a USB port on the front of the Xbox 360 console.
Flashing
green: The adapter is attempting to connect to a wireless network.
Flashing
red light: There is a problem. The adapter might be experiencing a
hardware failure. Contact Xbox support at http://www.xbox.com/support/contact
(http://www.xbox.com/support/contact)
No light:
The adapter is not receiving power. Unplug the USB connector and plug it
in again. Still no light? Try plugging the adapter into a USB port on
the front of the console
I am personally using a Plantronics CS60 wireless headset with a Meridian Nortel M2006 Phone and it works just fine.
Here is how you can setup the Plantronics CS60 wireless headset.
NOTE: Before setting up the system make sure the IntelliStand switch (on the right side of the charging base) is in the "_" position and NOT the "=" position.
The headset and the base unit are supplied subscribed to each other. However, if you wish to use a replacement headset with the base unit (or if you lose your connection to the base unit), then you must re-subscribe as follows:
1. Return the headset to the charging base.
2. Press and hold both the + and - buttons on the back of the charging base until the red light on the front of the base starts to flash.
3. Let go of both buttons. The red light should continue to flash.
4. Press the mute switch (black wheel on the top of the headset) straight down until a green light appears on the headset, then let go of the wheel, and the light should remain on the headset.
5. Resubscription is finished when the red light on the base is fully illuminated and the green light on the headset disappears.
6. Remove the headset from the charging base lift telephone handset/press headset button if not using a handset lifter. The headset and base should now be connected.
Please note that your hand receiver has to be off the hook when using the headset.
This is correct, additionally you can use a handset lifter accessory, such as the HL1 or HL10.
Subscribing Headset to Base:
7. If this procedure does not resolve your issue to try a system reset.
The compatibility setting, in almost 100% of the cases, should be set to "1". You can find it on the side of the base, it's a little turn wheel that will turn if you stick your thumbnail in it and twist. I have seen one instance on the Cisco IP phones that requires the compatibility setting to be on 5, so try that as well.
If you have a lifter installed, make sure that the short telephone cable that comes out of the back of the headset's base unit is plugged into the handset port of the telephone (where the handset coily cord is normally plugged into). You would then plug the handset coily cord into the front of the headset base unit. Make sure you have that configuration, and try again.
Finally you can try a re-set. To do this you should lift the headset off of the charging base, make sure the green light on the top of the base is off (the headset is off), and then do the following:
1. Hold down the mute button and the call answer button at the same time. (The mute button is the black little wheel on the top of the headset itself. If you use the tip of your finger to push that straight in, it will mute the headset)
2. Keep holding both buttons down until the green light below your thumb on the headset flashes for 2 consecutive series.
3. Let go. Wait about 20 seconds then try answering.
If this doesn't work, try a re-subscription:
1. Place the headset back on the charging base.
2. The two microphone volume adjust buttons on the back of the BASE unit should be pressed together. This will start the red light and the yellow light blinking on the front of the base unit.
3. Hold the mute button down while the headset is still on the charging base. Hold it down until the red light stops blinking.
4. Disconnect the power to the base so that the red light and yellow light turns off.
5. Plug the power back in after about 5 seconds of it being disconnected and make sure the red light on the front of the charging base is now solid and the yellow light is flashing.
6. Pick up the headset and try again.
NOTE: Before re-subscribing the system make sure the IntelliStand switch (on the right side of the charging base) is in the "_" position and NOT the "=" position.
To Re-Subscribe:
NOTE: Before re-subscribing the system make sure the IntelliStand switch (on the right side of the charging base) is in the "_" position and NOT the "=" position. To Re-Subscribe:
