20 Most Recent
Plantronics CS55/HL10 Wireless Office Headset System with Lifter 69702-01 Headset Questions & Answers
All of a sudden my
If the Plantronics CS55 wireless headset shows that it is on, you have to make sure of the following things.
a. the green LED on the base turns on when you turn the call switch on from the headset.
b. the small green LED on the side of the headset is blinking.
c. the telephone headset is lifted from the cradle.
d. if the headset is not charging and the Amber light on the base does not blink when you place wireless headset on it; trying placing the headset more firmly.
e. If the headset is not charging and the Amber light on the base does not blink even after placing the wireless headset firmly on the charging cradle, you may need to change the battery.
Alternately you can try resetting the Plantronics CS55 wireless headset.
Reset Plantronics CS50, CS60 or CS55 Wireless Headset
If you have problems with the sound or connection of your Plantronics CS50, CS60 or CS55 wireless phone headset, you may want to try to hard reset it using the following steps:
Note: Ensure the IntelliStand switch (on the right side of the charging base) is in the - position and NOT the = position.
1. Press both the call control button and the listening volume/mute button for 5 seconds. When the indicator light blinks release both buttons.
2. Press the call control button again. The talk indicator light will again blink to indicate the headset is back to normal.
3. Disconnect the AC charger from the AC charging jack for 5 seconds.
4. Reconnect the AC charger.
Now give the Plantronics headset a try.
Plantronics CS55/HL10 Wireless Office Headset System with Lifter won't lift headset
You may need to re-subscribe the headset.
NOTE: Before re-subscribing the system make sure the IntelliStand switch (on the right side of the charging base) is in the "_" position and NOT the "=" position.
To Re-Subscribe:
The headset and the base unit are supplied subscribed to each other. However, if you wish to use a replacement headset with the base unit (or if you lose your connection to the base unit), then you must re-subscribe as follows:
1. Return the headset to the charging base.
2. Press and hold both the + and - buttons on the back of the charging base until the red light on the front of the base starts to flash.
3. Let go of both buttons. The red light should continue to flash.
4. Press the mute switch (black wheel on the top of the headset) straight down until a green light appears on the headset, then let go of the wheel, and the light should remain on the headset.
5. Resubscription is finished when the red light on the base is fully illuminated and the green light on the headset disappears.
6. Remove the headset from the charging base lift telephone handset/press headset button if not using a handset lifter. The headset and base should now be connected.
7. If this procedure does not resolve your issue to try a system reset.
Plantronics CS55. When using the wireless headset
Echo is usually caused by the transmit (speak) level on the unit being
set too high.
1. First, try lowering the volume of the telephone. If you
still hear an echo, adjust the volume of the headset itself.
2. The master
transmit controls of the headset are the ABCD switch settings on the
bottom of the base. A is the lowest and D is the highest setting.
3. You
can fine tune this setting with the plus (+) and minus (-) buttons on
the back of the charging base.
4. If this doesn't fix the echo, try moving
the configuration dial on the left side of the charging base. The
recommended setting for most phones is 1.
On my plantronics cs540a i do not get a beep to let me know there is an incoming call.
If your Plantronics CS540A is not providing a beep to let you know there is an incoming call, there are a few things you can try to troubleshoot the issue:
- Check the settings: Make sure that the ringer volume is turned on and set to an appropriate level. You can adjust the ringer volume using the button on the base of the Plantronics CS540A or through the settings on your phone or computer.
- Check the mute button: Make sure that the mute button on the Plantronics CS540A or on your phone or computer is not engaged.
- Check the connection: Make sure that the Plantronics CS540A is properly connected to the phone or computer.
- Check the battery level: Make sure that the battery on the Plantronics CS540A is charged and that there is enough battery power to provide a beep.
- Check the software updates: Make sure that the Plantronics CS540A has the latest software updates installed.
- Check the settings of your phone or computer, there could be an option to turn off the ringtones of the headset.
- Check the volume of the ringer, it should be set to an appropriate level.
If none of the above steps resolve the issue, you may need to contact the manufacturer or a professional technician for further assistance. It's recommended to check the user manual of your device before trying any of the above steps, as the process of troubleshooting the ringer can vary depending on the model and manufacturer.
My plantronics cs350 wireless and headset no longer beeps when phone rings
- Make sure the volume on the headset is turned up.
- Check the settings on your phone to ensure that the ringtone volume is turned up and that the ringtone is not set to vibrate only.
- Make sure the headset is properly paired and connected to your phone.
- Check the battery level on the headset. If the battery is low, charge the headset.
- If none of the above steps resolve the issue, you can try resetting the headset to its factory settings.
If none of these steps resolve the issue, you should contact Plantronics customer support for further assistance.
Audio notification issue with BT600
since re-pairing caused this, please perform another re-pair and check for the pre-sounds beeps again. I'm guessing that you might have accidentally skipped a step in your first attempt and it led to this sound occurring.
Thank you.
PLANTRONICS SG_106 BATTERY REPLACEMENT
If it is the internal CMOS battery, it should be an easy swap. There is a high potential that this will reset the radio settings and you will lose all saved channels/frequencies, and have to reprogram them. Cell size is usually a CR2032 or CR2032R. The R is for the rechargable version, but not all equipment will do that. If it isn't a black socket that you can easily pop batteries in and out of, you may have to buy one with solder tabs or wires already attached. I don't reccomend trying to solder directly on the battery because it can fail and even expload from the heat.
