WOW magic sing model TKR-320. 2 wireless microphones not working but power turning on
SOURCE: vocal problem
hi there..if there is video and background audio coming out from the TV, and no voice recognition from the mic- then mic is the problem. I believed the problem is the "voice coil". This is a part that can be replaced- you can contact me and we can repair that.
two ways to check
remove the mic ball
the part which the mic ball is is covering is the voice coil.
try holding both terminals (black and white wire)- if there is feedback sound- it is open and need to be replaced
try using your tester- test the impedance- there should be 500- 600 ohms reading
([email protected] or customerservice @magicmic.com)
SOURCE: I have a EnterTec Karaoke
Make sure the microphone is turned on and the batteries are brand new. Next, make sure the microphone is plugged in securely and turn the mute switch off on the microphone. If it is still not working then click on the link below and send it in for a free replacement:
http://www.magicsing.org/Contact-Us/Magic-Sing/
http://www.magicsing.org/Enter-Tech-Magic-Sing-Troubleshooting-Tips.html
SOURCE: 2-second delay with Magic Sing
i bought et18k. just the same as yours.its 2 days old and has the same problem. the technical assistant says that its because of the digital setting that new tvs have. there are two ways to solve this though:
1. connect the video (yellow plug) to the tv. and the other two plugs (yellow and white) to the stereo. when i say stereo, its not the dvd home theater system that you have but a separate one. if you connect it to the home theater that you have, it'll just sound the same, you still have the delay.
2. connect the magic sing to the older tvs hangin out. and you'll get no problem at all.
**TVs such as sony, samsung, philips, sharp and all plasma tvs including other newly designed tvs will have the delay since they all share the HDMI thingy that causes sh*t.
SOURCE: Cord broken for Magic sing microphone
If you need a cord or any accessories please contact or email me at [email protected]. i'll be glad to help you.
SOURCE: broken karaoke mic ed8000 model
Hi im joe,
if the screen says no font, no picture, no song data it means all the data installed was lost. you have to send it to the nearest service center to have it reprogram.
