To run the check disk utility you will need a repair disc or
a operating system disc. Put the disc in the cd drive and boot from
it. You want to get to the Dos Command Prompt (Black screen with white
letters) and type the following commands and press enter after each one:
sfc /scannow
chkdsk /r
Check disk will run well over an hour or two and you will notice the
percentages going from high to low, this is normal. Let it run to
completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.
Try doing a Repair Install that way you don't loose your data, documents,
music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when
the options appear.
In Vista and Windows 7 you want to get to the recovery
console and look down at the bottom of the window for the Dos Command.
1. Check your BIOS to be sure your computer will boot from a CD.
Enter the BIOS setup by pressing the "Delete" or F2 or "F12"
key, or as directed at the startup screen, immediately after booting. Set the
first boot device to "CDROM" or "DVDROM" instead of
"hard drive" if it isn't already.
2. MS-DOS command prompt
Insert the Windows XP installation CD into your CD or DVD drive
and restart the computer. When prompted, choose to start from the MS-DOS
command prompt with CD support. The MS-DOS command prompt will appear in a
moment.
3. Start SMARTDRIVE by typing "SMARTDRV" at the DOS prompt
and pressing enter. You don't have to run SMARTDRIVE, but copying the files
will be much quicker if you do. The computer will display the DOS prompt again.
4. Enter "CD I386" at the DOS prompt to change to the
directory where the setup program starts.
5. Enter "WINNT" at the prompt to start Windows XP setup.
The installation program will copy files to your computer and then display a
message requesting to reboot.
6. Press the "Enter" key to reboot. The setup program will
start again and check that your hard drive format is compatible with Windows
XP. If not, it will guide you through partitioning and formatting the drive and
then ask you to reboot once more.
7. Press "Enter" to reboot. The computer will restart in Windows XP mode and automatically start the Windows Setup Wizard to detect your hardware and finish the installation.
