Cant install xp on my compaq cq40-108tu laptop..pls help
I cant install windows xp sp2 on my compaq cq40-108tu laptop.. i already flashed my bios to f.11c..i also tried to insert those ahci drivers on my installation disc using nlite.. please help
Posted by kingcindy06 on
jessie batacan
  • 59 Answers
Try to use windows xp sp2 with bootable
just make sure it is bootable.
Posted on Apr 30, 2009
\$WIN_NT$.~BT\biosinfo.inf could not be loaded
Should be here: C:\WINDOWS\inf\biosinfo.inf
Sep 01, 2009 | ASUS Eee PC 1000H Laptop
How i can install xp sp2?
for bios update go to manufacturers website but to install xp sp2 on this lappy you will have to install third party raid driver and legacy device driver that you can download from www.download .com
May 09, 2009 | Computers & Internet
How to install windows xp sp2 on compaq v3239tu
That happens because the BIOS uses a SATA controller that is not included in Windows XP install disk.
Usually you can solve the problem going to BIOS settings and changing SATA/RAID settings.Check your BIOS settings, and disable SATA RAID mode.This is done in different ways depending on the BIOS.
On HP/Compaq computers for example you press F2 on startup to enter BIOS, then disable SATA mode on bios settings.
On other makes the procedure can be slightly different.
Another way to fix the problem, is by creating your own XP setup disk with SATA drivers included, see:
Resolving "Setup did not find any hard disk drives" during Windows .
Mar 14, 2009 | HP 417068-001 Compaq Presario V3000...
Touchpad not working after re-install windows XP SP2.
You can't load Windows XP over Vista. Microsoft has it in the BIOS that it cannot be overlaid with an older system. The only way to use XP is to attempt to dual-boot but that will take you some research. Load vista back...don't blame me Microsoft screwed us..
Pls rate solution.
Feb 28, 2009 | Acer Aspire 5610-4648 Notebook
Windows os
Its true. the Bios or HDD driver wont allow you to install Win XP on it.. This BIOS is compatible with only Win Vista. The only easy way to do it is by creating 2 partitions while installing vista. once vista is installed- install XP with Dual boot and than format the vista partition.
Feb 04, 2009 | HP Compaq nc6000 Notebook
Disable sata in bios of compaq CQ40 laptops
i m not able to install windows xp on my compaq cq60 104tu laptop
when i boot the cd the exatrating process work properly and after extraction of all file when windows is startup a blue screen appears and
and message displayed in the screen check ur hard disk for vireuses
and installation stop
Dec 20, 2008 | Compaq Presario Notebook
I m not able to install win xp sp2 on my compaq notebook
windows xp cant detect ur hdd bcoz its SATA hdd.
Solutions:
1. Install vista instead of XP
2. You need to disable this SATA feature in BIOS to install OS.
SATA disable steps.
1. Restart the computer and start tapping F10 key.
2. Choose System Configuration tab.
3. Disable SATA native support.
4. Save and Exit the BIOS by pressing F10 key
Aug 21, 2008 | HP Compaq Presario V5000Z Notebook
Computers & Internet Logo
566 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
