Whirlpool Duet GHW9150P Front Load Washer Logo
Posted on Feb 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Our washer keeps stopping and flashing F11 and will not finish load
Anonymous
Level 2:
Novelist:
  • Expert 99 Answers
  • Posted on Feb 11, 2011
Anonymous
Expert
Level 2:
Novelist:
Answers
99
Questions
0
Helped
14016
Points
138
The F11 code is saying that there is a problem with the motor or motor control board, both at the bottom of the machine. Most often the problem is not there but rather in the communications between the CCU circuit board and the motor or motor control board. The CCU circuit board (inside back, top of machine, plastic case) has what's called cold solder joints where the relays (5 of them) and the spade connectors are supposed to be firmly soldered to the circuit board. Whirlpool had a quality control problem with these circuit boards but won't recall them. The cure is to remove the CCU circuit board in the plastic case (it's easier that way) then remove the circuit board and touch-up those cold solder connections I mentioned. If your not up on soldering techniques, you can remove the CCU case, with the circuit board inside, and take it along with this response, to a good appliance repair shop and they should be able to help you out. Good luck.
Lights keep flashing and door locks without finishing cycle
Kenmore HE2 Plus Front Load Washer Keeps unlocking ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
flashing prewash and add garment lights My HE2 Plus will fill with water, but when ...Kenmore HE3 2plus wont finish cycle Washer wont finish the last1 minute of cycle. ...We ran a load twice and it still did not unlock. du is the code for cannot ... Why does the door keep unlocking and locking in between the drum rotating?
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following symptoms: Not Completing all Cycles ...
Washing machines - Ariston
1helpful
4answers
F11 code flashing-washer stops
hi!!!!
try to unplug it end then check the control timer if it is broken !!!!
or open it if you know and fix it may be the spring that pull back the pause botton
might be broken go check it?
Washer stops and F11 code flashes
An F11 is a communication failure between the machines control board and the motor controller. Often you will also experience a 'DL' error associated with the F11 because when the washer fails, the door is still locked and when you restart the wash, the electronics will try and lock an already locked door. Either the control board or motor controller can cause this error along with a bad harness or loose connector, but the majority of the time it is the main control that is failing.
Our front load washer flashes f11 and stops in middle of load and will not finish.
I wrote a solution before but it's not showing up as delivered to you so I'll try again. The F11 code is saying that there is a problem with the motor or motor control board (MCU) Most often the problem is communications from the CCU circuit board and the MCU. The problem is that there are cold solder joints on the CCU board at the point where the relays (5 of them) and the spade connectors are supposed to be soldered firmly to the board. The repair is to remove the CCU case (inside, top, back of machine) then remove the circuit board and touch-up those cold solder joints I mentioned. If your not up on soldering techniques just take this response and the CCU case, with circuit board, to a good appliance repair shop and they should be able to help you out. Good luck.
F11 error lights flash then stops at last spin . I did clean the filter and took some coins out Whirlpool AWM8163 washer
The F11 fault is the motor. I have had this issue myself and found that replacing the contact brushes solved this. The brushes on most electric motors are made from carbon, and wear down with use. They are spring loaded but have a limited life span. These are also cheap to purchase.
Cylce stops after 1st drain before spin out
I have kenmore washer front load H2 after 1st circle of wash it stop and start beeping with code F11. My email address is anarfi1212@ live.com
Washer stops in middle of load and flashes F11.
this is not good . F/11 CODE serial communication error . the communication between the central control unit (ccu) and the motor control unit (mcu) cannot be sent correctly . now that sounds bad . don't panic!! ck the wir harness connectors to the mcu ( motor ) and ccu ( program panel . something is loose/ also ck the drive systen for any worn of failed components .belts/pulleys/ leakage.. ck mcu/ the ccu/ ck motor/ ck wire harness. -hope this will help . (look for loose connections this is most common.. mm
F11 Kiss of Death!
f11 is in my experience has been a faulty rear board, its really a communitcation error betwwen the control board, the latch and the lower motor control board(rarely an issue with the motor controller, but have seen faulty wiring(in which case had to replace the entire wire harness, as well as ann occasional door latch. keep after it under warr, so when it does runn out youll have records of attemps to fix while underwarr and make them make good on repairs after warrr expires
Flashing F11
rmove top and ck connectors to rear mounted main control module f11 is code for communication problem between upper main control and lower motor control..most likely upper control problem tech sheet behind lower panel
11helpful
4answers
Hotpoint ultima wt741
hi i have a hotpoint condenser tumbledryer with the eroor code f11 coming up its a hotpoint ultima ctd85 can anyone help pls
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
