My samsung entro cellphone won't turn on. when i try to turn it on, the samsung loading screen comes up for about 7 minutes then goes to a blue screen and doesn't turn on. how can i fix this so that it will turn on?
if you have a memory card you can try takeing that out cause that was a problem with mine about a moonth ago but now mine just wont turn onif you have a memory card you can try takeing that out cause that was a problem with mine about a moonth ago but now mine just wont turn on
You can't post conmments that contain an email address.
Your Graphics Adapter may be out? Have you tried to boot to Safe Mode or a System Restore/Recovery? Have you done ANY updates? Remove ALL media, CD,DVD,USB, unplug, remove battery, leave battery out, plug in, reboot, Try this Win 7 procedure: http://www.sevenforums.com/tutorials/666-advanced-boot-options.html The other option is to re load Windows.
i have had one of these myself... this pc suffers from various problems, mostly motherboard. Your specific problem has happened to a couple of friends, both filled their drives up so much that it "blue screened" We all know blue screen is often terminal. Your machine is getting on now. clear your drive up from DOS and windows ( delete unneeded files at start up, not through windows if possible.
How to unlock Samsung m350 If you got a second handset cellphone and
want to use it on other carrier, you have to input an unlock code to access the
phone on the home screen. The phone may ask you to input the MSL code, that is
just the unlock code for your phone. Here I am going to tell you how to unlock
your Samsung Entro m350, it is also called Samsung Seek m350, they are actually
the same phones.
If it is the first time you are going to unlock the
Samsung Entro, you just need to power on your phone, and press ##111111#. This
can be use only once, the second time you want to change carrier on your phone,
you have to call the carrier for the 6 digit MSL code of your Samsung Entro,
then take the following steps to unlock your phone fo
I just had a similar problem with my Samsung Comeback. It was doing the same thing, as well as freezing and being very slow to load. My solution was to remove the battery, and the memory card, reinstall the battery and start it up again. I had to cycle through on/off three or four times before it sped up to normal again.
This seems to have happened because my phone powered down overnight because it needed to be recharged. I recharged it right away, and put my memory card back in. It all seems fine now.
