20 Most Recent Samsung R530 Notebook Questions & Answers
You can download the WEBcan and device drivers from the Samsung WEBsite. Please click on this link and select your model computer/notebook and theWindows drivers you require :-.http://www.samsung.com/us/support/
Samsung R530... | Answered on Jun 21, 2019
So many computer face this blue screen fetal errors on windows.
This error comes usually when there is problem in software or driver compatibility issue with hardware or operating system.
Also this error comes when there is bed indexing unit in hard drive.
You can solve this errors with following 2 methods.
(1)When you power up the computer press F8 key then enter in safe mode.
Then if you are able to enter in safe mode then uninstall driver or software which you installed recently and face this error.
(2)If you are not able to enter in safe mode Then you need to fix error on hard drive.For that you need windows disk or recovery disk.
Boot your computer with that disk
For that when you power up the computer press F1 or F2 "del" key to enter in bios.
Then go to boot menu and set first boot device as your cd or dvd rom.
Then save settings and exit bios.
Insert windows disk in cd /dvd rom.
Then it boot with that disk.Then you get this message "Press any key to boot from cd.."
Then press any key.
Then follow the procedure then enter in recovery console mode then type in prompt "chkdsk /r"
Then type "y"
Then it fix error on hard drive.
Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windows " then it repairs old windows then it loads again old windows.
Thanks for using FixYa.
Samsung R530... | Answered on May 30, 2019
Try using the laptop without the battery and observe.
Following the link below for instructions on how to remove the battery on this laptop.
Samsung Series R530
Samsung R530... | Answered on Oct 04, 2018
The product key is only put on the bottom of the Laptop and can not be found else where.
Samsung R530... | Answered on Jun 03, 2016
To delete your phone number (or see if your number is listed), log in to Facebook and click the gray Edit Profile button in the upper-right corner of your profile page. Then, in the left-hand column, click on Contact Information.
How to remove your phone number from Facebook CNET
Please rate my answer, give me thumbs up pls, Thk you.
Samsung R530... | Answered on Dec 02, 2015
if you dont have the disc to get the driver try asking windows updates to find it,if not put make and model and what you are running into a search page and ask it to take you to a dowload site that may have the driver you are looking for.might work.
Samsung R530... | Answered on Apr 12, 2015
driver update from samsung website
Samsung R530... | Answered on Mar 30, 2015
The power socket needs tightening up so it grips the plug. That will stop it disconnecting.
Unfortunately not easy to do.
I would return the unit under warrantee and explain "it is not fit for purpose" and should be repaired for free. That should speed up the repair time!
Here is the manual. Page 44 shows the DC Jack.
http://downloadcenter.samsung.com/content/UM/201409/20140901105526126/Win7_Vista_Manual_eng.pdf
Samsung R530... | Answered on Mar 04, 2015
check the cable to your scrren or reintall your operating system
Samsung R530... | Answered on Feb 03, 2015
goto www.ninite.com
click in the box next to cdburnerxp
click on GET INSTALLER at the bottom
now it may work for you using cd burner xp
Samsung R530... | Answered on Dec 02, 2014
Error message when you try to install Windows Vista on computer that has...
This problem occurs because Windows Vista cannot distinguish between ambiguous hard disks.
In versions of Microsoft Windows Setup that are earlier than Windows Vista Setup, hard disks are marked with distinct values to distinguish them. However, this method of distinguishing hard disks is no longer supported because of the potential for data corruption on hard disks.
Do you have more than one hard drive connected to your computer?
If you have two hard drives, remove the second hard drive and continue with the installation.
If that does not work, try to format the C: drive while installing the Vista operating system.
You need to select the "format" option from "advanced" within Vista installation.
Click on the link below for more information.
Error message when you try to install Windows Vista on a computer that has uninitialized hard disks: "This computer's hardware may not support booting to this disk"
http://support.microsoft.com/kb/925481
It is normally turned off to stop feedback. Go into the sound settings on the control panel and enable it.
Samsung R530... | Answered on Sep 14, 2014
I can't tell you what to do for your problem, however you have to decide what to do. Check the following information from http://www.file.net/process/ssckbdhk.exe.html
What is SSCKbdHk.exe?
SSCKbdHk.exe is a executable file (a program) within Windows. The filename extension .exe denotes an executable file. You should only run executable files from publishers you trust, because executable files can potentially change your computer settings or harm your computer. The free file information forum can help you determine if SSCKbdHk.exe is a virus, trojan, spyware, or adware that you can remove, or a file belonging to a Windows system or to an application you can trust.
SSCKbdHk.exe file informatiion.
The process known as SSCKbdHk belongs to software Samsung Support Center by SAMSUNG Electronics (www.samsung.com).
Description: SSCKbdHk.exe is not essential for Windows and will often cause problems. The file SSCKbdHk.exe is located in a subfolder of "C:\Program Files". Known file sizes on Windows 7/XP are 91,136 bytes (57% of all occurrences), 1,749,504 bytes and 4 more variants.[img src="http://www.file.net/img/space.gif" alt="http://www.file.net/process/ssckbdhk.exe.html" width="1" height="1">
The program has no visible window. It can change the behavior of other programs or manipulate other programs. SSCKbdHk.exe is not a Windows core file. The software can be uninstalled in the Control Panel. SSCKbdHk.exe is able to record inputs. Therefore the technical security rating is 42% dangerous, however also read the users reviews.
If problems with Samsung Support Center come up, you may want to uninstall it from your computer using the Control Panel applet "Add/Remove programs".
Recommended: Identify SSCKbdHk.exe related errors
Important: Some malware camouflages itself as SSCKbdHk.exe. Therefore, you should check the SSCKbdHk.exe process on your PC to see if it is a threat. We recommend Security Task Manager for verifying your computer's security. This was one of the Top Download Picks of The Washington Post and PC World.
Samsung R530... | Answered on Aug 21, 2014
Question carries insufficient details; however, if you mean you want to connect your Note-Book PC into a TV monitor - you have 3 options, depending on the type of cable you have - see the following three (RGB, HDMI & DIV). If both your computer and TV feature one of those ports shown bellow, you can connect your Note Book Computer to your TV set.
ddc0ca37-d06d-4709-b564-8dfc30ffd745.jpge3db72c2-73f2-48f2-9312-e40cafc51558.jpg de975010-ff1c-4349-991a-ec3562c18219.jpg
Please give me a vote if my answer helps.
Samsung R530... | Answered on Aug 18, 2014
Under the battery
Samsung R530... | Answered on Aug 02, 2014
Without the correct password, the hdd is unusable. You cannot even format it.
Samsung R530... | Answered on Feb 19, 2014
Samsung R530 Notebook Logo
155 questions posted
Popular Products
Top Samsung Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
ThaMp3Doctor
ThaMp3Doctor
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
R Samsung
  • R Samsung
Most Popular Question
connect ipad 1 pc
  • Computers & Internet
