We loose connectivity to our isp. we maintain connectivity to the wireless router. The lights on the cable modem are on solid with no activity on the pc activity led. So I reset the box (power off for a minute). Then it starts the power up/reboot sequence and only 1 light comes on. I wait about 30 seconds and reset again. This time it completes and we can connect. THis pattern has been going on for about a month. Probably need to reset 3 to 4 times a week. Cable modem going or ISP related?
If you don't have a PPoE password from your ISP, then just connect the ISP modem to the main port on the router. Then connect a PC with a network cable. This should work, if not try connecting the modem directly to the PC to test. If you get internet with just the modem, then try resetting the router.
If the wireless device is working properly the LED's blink when transfering and receiving data. Even when not in use the ISP modem and the wireless device will blink. I would start by Checking ALL cables in the network, verify the cable connections. Have your ISP verify the signal, if necessary have a ISP tech come out to analyze the signal.
Here are the recommended steps to connect to a wireless base router 1. Check and remove power from both your router and the DSL ROUTER/CABLE ROUTER MODEM 2. Wait one complete minute until applying power to modem then wait one minute before applying power to wireless router. 3. Ensure you have green lights across both devices, specifically, the recieved and sent lights. These same lights will tend to blink rapidly when there is active data, at times this will still blink, and a DNS error will prevent you from connecting to the internet. If this is the case, call your ISP Internet service provider 4. Check your authentication Security key on your router first, then check all your wireless devices to ensure they are on the same network name, key, and channel with the same type of encryption as the router 5. Start one device at a time and check for connectivity, if your still experiencing a problem, check the settings on all your wireless adapters, device drivers, internet browser settings, firewalls and proceed. 6. still have problems, connect a rj45 cable from the router directly to your computer to at least see if your wireless settings are bad or if the router may be bad. 7. Contact your ISP to determine if your receiving singal 8. Avoid using a splitter or parital power backup for yours routers 9. Still having problems, change your wireless router only after your ISP changes their faulty modem 10.Attempt the same process when setting up your new wireless router and or modem
The flashing blue light is absolutely normal!!! Please follow these steps to configure your computers to your wireless router
Are you trying to set up the router ?
First make sure that your computer is online when connected directly to the mdoem. ISP is DSL.
If not online through the modem then you should have user name and password for the ISP.
try to reconfigure the router. Click Here for more info about router set up.
