20 Most Recent Belkin Wireless Play Router (F7D4302) Questions & Answers
belkin does not support this. The only way you can do it is by running a cable to the router to extend your wireless signal around the house. I did a similar setup with a powerline network adapter if running a cat5 cable is not a option. just make sure you change the main ip address for the 2nd router to like 192.168.2.2 and disable dhcp since the main router will handle dhcp. also make sure the wireless settings are the same and channel is different if 1st router is channel 1 then use channel 6 or 11 for the 2nd router.
Belkin Wireless... | Answered on Jun 01, 2017
You need to reset your Router before setup manually.
To restore the router to factory default settings, please do the following:
1. Unplug the router's power supply
2. Press and hold the reset button on the bottom of the router
3. Keep the reset button depressed and, at the same time, plug the power supply back in
4. Keep the reset button depressed for another 10 seconds
5. Release the reset button
======================= Manually configuration ==============================
Step 1 : Connect modem - Router - Computer ( Wired )
Step 2 : Open router setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left side under internet WAN click Connection Type
Step 4 : leave the Password Blank and click submit
Step 5 : Choose the connection type as dynamic and click next
Step 6 : Leave the Host name blank and click apply
Step 7 : On the left Under Internet WAN Click MAC Address
Step 8 : Click Clone and Click Apply changes
Step 9 : If the Internet status on the top right is connected
Step 10 : Then check if you have internet
Step 11 : if not Then unplug the Power Cable from the Modem And the Router
Step 12 : Plug the power Cord to the Modem
Step 13 : Wait till all the lights are on
Step 14 : Plug the power to the belkin
Step 15 : Check the color of the light in the belkin
Step 16 :If green then Check if you have internet
If not working then call belkin
WIRELESS SETTING UP A WIRELESS CONNECTION
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Belkin Wireless... | Answered on Aug 04, 2015
Routers usually don't need installation disks unless you are using the USB port. Connect the yellow ethernet port your modem, and then one of the "Wired" ports to a computer. If it goes well you should be able to get it work. To setup the wireless, google search "F7D4302 setup wireless". The first link that comes up will let you download the manual.
Belkin Wireless... | Answered on Dec 30, 2013
If you don't have a PPoE password from your ISP, then just connect the ISP modem to the main port on the router. Then connect a PC with a network cable. This should work, if not try connecting the modem directly to the PC to test.
If you get internet with just the modem, then try resetting the router.
Wireless takes
Belkin Wireless... | Answered on May 29, 2013
Default address is 192.168.2.1. You can verify this on connected PC. Go to Start > Run > type cmd Type ipconfig /all
Belkin Wireless... | Answered on Aug 31, 2012
First crosscheck with Belkin that whether the said 3rd party file is compatible and recommended with your router's configuration or not, else it may corrupt the router. get their suggestions.
Or try 1) remove the extension .bin and try again to upload the same.
2) replace extension .bin to .conf and try again.
Note I am not responsible for any Firmware damage caused in your device due to the upload, pls be sure enough before proceeding any upload.
Regards:
Himanshu
Belkin Wireless... | Answered on Aug 28, 2012
Hi susan there is not reset needed just login in to your setup page to change any password.
Connect the pc direct by cable to the router
Go to explorer and type in the bar address
192.168.2.1 enter
and go to security
after that you can change the password
any questions just call me
Belkin Wireless... | Answered on Jan 03, 2012
Wireless routers can change the type of security key such as WEP, WPA and WPA2. WEP is the weakest type of encryption, and WPA2 is the strongest. To see what kind of key you are using, log into the routers ip address (Defualt gateway address in ipconfig command) then find the area for wireless security. The type of key and the key should be displayed.
Belkin Wireless... | Answered on Mar 02, 2011
Your other computers must be connecting to the Belkin using WEP encryption if the Belkin does not support WPA encryption.
Therefore you need to configure the wireless card in the HP with the Belkin's WEP encryption key.
Belkin Wireless... | Answered on Mar 01, 2011
Try this
Uninstall The Belkin Router monitor Software from Control Panel
Restart the Connection
Regards
Tom
Belkin Wireless... | Answered on Jan 30, 2011
I got your issue, I hope you are trying to connect the 2nd router to the first router through LAN-LAN connection (i.e, LAN port of the first router is connected to the LAN port of the 2nd router)
Then you need to change the ipaddress of the 2nd Play Wireless router . Please follow these steps.
1. Connect the computer-router with ethernet cable and open up internet explorer and clear the address box and type in 192.168.2.1 and hit enter.
2. You will be logged into the Belkin router setup page, in the Left hand side under LAN setup click on LAN settings
3. It will ask for Login password, leave it blank and click on submit
4. Change the LAN ipaddress from 192.168.2.1 to 192.168.5.1 and click ok
5. The page will say cannot be displayed, then clear the address box and type in http://192.168.5.1 and hit enter
6. If your first router is connected to the internet , then automatically the internet status will says connected
7. You will be able to go online wired
Good Luck!
Thanks in Advance!
Regards,
Prema
Belkin Wireless... | Answered on Dec 29, 2010
Download the software from Belkin website and try to install it:
http://en-us-support.belkin.com/app/answers/detail/a_id/3712/~/f7d4302-play-wireless-router---setup,-router-monitor-software-and-apps
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Definitely Belkin is compatible with all the operating systems. the issue is the security type that came along with the router is WPA/WPA2... it is not compatible with many computers. Changing the security type to WEP64 bit will work perfectly...
Belkin Wireless... | Answered on Dec 20, 2010
WIRELESS SECURITY ISSUES
Belkin Wireless... | Answered on Dec 12, 2010
Belkin Wireless Play Router (F7D4302) Logo
52 questions posted
Top Belkin Computers & Internet Experts
Ekse
Jeffrey Groves
Jeffrey Groves
Mike
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Belkin Computers & Internet
Most Popular Question
cannot connect web interface
  • Computers & Internet
