20 Most Recent 2wire (2701HG-B) Wireless Router Questions & Answers
2answers
Where can I find the IP address of the router
The default IP address varies depending on the ISP you are using and the software version.
The common IP addresses are:
  • 172.16.0.1
  • 192.168.0.1
  • 192.168.0.254
  • 192.168.1.254
8/18/2018 12:06:50 PM • 2wire (2701HG-B)... • Answered on Aug 18, 2018
How can I desactive of MAC address on my wireless router?
Reset your wireless router to factory settings. On the back or bottom of your router, you will find a small hole perfect for a paperclip to be inserted. While it is plugged into power, press an unbent end of a paperclip into the hole firmly for 30 seconds then release it. Your router should now be at the factory settings. You will need to set up the router very quickly to change the factory Admin password so that nobody else can get into it. Get your setup instructions online by going to the router's manufacturer page to find the manual for your specific router.
2/7/2018 5:43:39 PM • 2wire (2701HG-B)... • Answered on Feb 07, 2018
2answers
What does a red internet light mean and how do I
You'll need to contact your ISP and have the DSL service moved to the new line. The laptop sees the mdem or router and thinks it's connected, but the red internet light tells you the connection is not complete to the phone company.
1/25/2018 1:28:44 AM • 2wire (2701HG-B)... • Answered on Jan 25, 2018
My new modem keep shutting down once in a while
Did AT & T supply it? If so get back on to them and tell them it;s still happening and if they don't sort it out, you will subscribe with another company.
11/3/2017 2:05:59 PM • 2wire (2701HG-B)... • Answered on Nov 03, 2017
I have a 2wire router from AT&T and I cannot
I've never had any restrictions, I have an internal router, and several computers and devices access the internet through my AT&T account both wired and wireless. I don't know anything that would prohibit you using a machine to connect to the internet through one of their routers, and the fact that it can connect locally, if by locally, you mean you can access other devices connected to the router, then as a network analyst, computer guru, the only thing that I can think that 'might' interfere is your IP address on your computer; but, that would restrict the other devices from connecting to the internet too, or the laptop but not both. But, to me it sounds odd that you have such an issue, it has to be the way the network is configured on your laptop. If you know, you can check this through the DOS or Power Shell on your laptop. I presume it's windows, at the prompt, if windows, just type ipconfig /all <return> = C:\ipconfig<sp>/all<return> to check your network card IP and mask settings for all devices that could connect to the internet. Perhaps your laptop is IPv4 and the AT&T is set to IPv6 only, something like that.
7/3/2017 4:57:01 AM • 2wire (2701HG-B)... • Answered on Jul 03, 2017
2701HG-B ATT modem/router won't answer ping 192.168.1.254
what is the default gateway for the ip address of whatever computer you are using ? Not sure if they can change it but looking up the default gateway ip address will give you the router ip address if DHCP is being used and if it has changed somehow ?
6/7/2017 3:33:32 AM • 2wire (2701HG-B)... • Answered on Jun 07, 2017
I forgot my password, where do I go for assistance
Resetting the System PasswordIf you forget your password and still cannot remember it after seeing your hint, click the I still can't remember the password link.The Reset System Password page opens.To obtain access to your system:1. In the System Key field enter the 10-digit system key located on the bottom of your gateway. 2. In the Enter New Password field, enter a new system password. In the Confirm New Password field, reenter the system password.3. In the Enter Your Hint field, enter an appropriate hint as described under "Setting a System Password" .4. Click Submit.Setting a System PasswordSetting a system password protects your gateway settings from being modified or changed by someone who has not been given permission to do so. After setting a system password, you will be required to enter it whenever you attempt to access a gateway configuration page - for example, if you try to change the gateway's broadband connection settings or upgrade the gateway software. If a password has not been set, a reminder notice is displayed when you attempt to access pages where settings can be changed.To set your system password: • Open a Web browser and access the gateway user interface by enteringhttp://gateway.2wire.net.• Click the System tab.• Click the System Password link in the System area of the Network at a Glance panel to open the Edit System Password page.1. In the Settings panel, click the Enable checkbox. 2. In the Enter New Password field, enter your password. 3. In the Confirm New Password field, re-enter your password. 4. Optional: In the Enter Your Hint field, enter a hint. A hint is a word, phrase, or question that reminds you what the password is. There is an I forgot the password link on the password entry page. When you click this link, it shows you your hint and allows you to enter your password.5. Click SAVE.
6/1/2017 6:27:01 AM • 2wire (2701HG-B)... • Answered on Jun 01, 2017
2answers
I have an at&t 2wire
att 2 wire is a Adsl Modem (Requires a telephone line jack to get the signals) but charter communication is a cable internet service (not DSL) , Requires a TV cable service for internet .These two jacks differs and there working differs ..Means : Att works with the username and password type of authentication but charter requires the MAC address of modem for authentication . Therefore for a cable internet 2wire 2701hg-b modem cant be used . But yes in case charters has username and password authentication and works with the telephone jack in house then its possible to use the same modem.
2/23/2015 7:22:32 AM • 2wire (2701HG-B)... • Answered on Feb 23, 2015
Billion 7300nx router red power light come on
Try another outlet. If problem persists then try another power cord if you have one or you might need to replace it.
11/4/2014 1:14:18 AM • 2wire (2701HG-B)... • Answered on Nov 04, 2014
Forgot my password for my wireless 2wire136
just go to router wifi use via browser
3/29/2014 2:33:22 AM • 2wire (2701HG-B)... • Answered on Mar 29, 2014
0answers
0answers
Forgot my password
Reset the router. There will be a pinhole on the back of the device. Use a paper clip to depress this for 30 seconds I’m happy to help further over the phone at https://www.6ya.com/expert/michael_2ebcd3cbc4810dbf
10/8/2013 1:40:47 AM • 2wire (2701HG-B)... • Answered on Oct 08, 2013
2wire (2701HG-B) Wireless Router Logo
299 questions posted
Top 2wire Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • 2wire Computers & Internet
Most Popular Question
wireless light flickers computer looking
  • Computers & Internet
