Arris Sb6141 Surfboard Cable Modem Sb 6141 Docsis 3.0 Logo
A
Anonymous Posted on Jul 27, 2012
Surfboard 6141 default password
Need to log in as admin but never set a password. Is there a default one for this device?
Nate
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Sep 25, 2014
Nate
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
17171
Points
9
User: admin
password: password
If you have a retail one it probably won't work.
Instead go to http://192.168.100.1/index.htm
Jana Ortiz
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 1 Answer
  • Posted on Jan 08, 2019
Jana Ortiz
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
Questions
0
Helped
16108
Points
Are the methods explained in this thread are working?
192.168.l.l0
3 Related Answers
Anonymous
  • 217 Answers
  • Posted on Sep 08, 2011
SOURCE: i don't remember setting up
Default admin username:admin Default admin password:motorola
Default SSID (wireless username):Motorola
you can also check out this link to have a clear picture of a default settings of your modem: http://bc.whirlpool.net.au/bc/hardware/?action=h_view&model_id=181
for additional concern kindly leave a comment and i'll get back on you ASAP...
---a score of 4 is highly appreciated----- ---if you think this resolution is helpful kindly click on "YES"---- ---you may also leave testimonial----- ---if I help you please help me---
Thank you for choosing fixya
Roger
Anonymous
  • 6 Answers
  • Posted on Sep 23, 2010
SOURCE: i was using the default
Default IP address192.168.100.1 Default admin usernameno usernameDefault admin passwordno password
sodeep
Sudeep Chatterjee
  • 3267 Answers
  • Posted on Jun 04, 2011
SOURCE: i forgot my router password
remember to hit reset while its plugged on & use a toothpick or paper clip
Turn wifi off
Log in to the modem as if you were going to change the wirelessicon1.png password (browse to default gateway and enter username and password) then turn off SSID broadcast (usually by un-checking a box)
try these
Default IP:
192.168.0.1
Default Password:
motorola
Default Username:
admin
Cant log on to the wireless motorola 192.168.0.1
If you got to the router's interface by typing 192.168.0.1 and it requested the userid and password. If the password you enter did not let you in, then the password is wrong. Maybe someone changed the default userid and password to something else.
You can always press the reset button on the router to set it back to Factory Settings. Then the default userid and password will work, but you will have to set the wireless back up and configure the basic settings (if you have a userid and password that the phone company uses as the network userid and password. This is not your email address userid and password).
I don't remember setting up a user ID and password for the motorola sbg900. when i tried logging in using the default password "Password" and default user ID "motorola", I...
Roger
How to change the password on a Motorols Router S85100 Surfboard
The default password for this routers is usually motorola and the username is password.
You can reset the device to default factory seconds by pressing the reset button for more than 30 seconds.
The you can log into the router suing its IP address on your web browser and go into the device settings to change the username and password.
2answers
Trying to secure my wep, tried the loggin admin, motorola but will not log me in.
Couple of things you can do....
In the User ID field, type admin (case sensitive) and press TAB. In the Password field, type motorola (case sensitive) and click Log In to display the SBG900 Setup Program main window
If you are still having problems, try the following:
  1. Press the reset button on the rear panel. Resetting may take 5 to 30 minutes
  2. Try the login again, if that fail try from a different browser.
I can't log in the "Gateway admin", the password error?
unless it has been manually changed the default username is admin and the password is motorola... and the default gateway address will either be 192.168.0.1 or 192.168.100.1
Forgot the password on the surfboard router
Here are the default settings:
Disabling firewall?
by default, you can get to the surfboard configuration page by http://192.168.100.1. username: admin / password: motorola
username and password are case sensitive.
if you dont know the password better get it from your roommate to avoid resetting the modem back to factory defaults. if there's no other way to retreive it you can reset it by pressing the reset button on the back of it for 5-10sec.
after resetting, according to the manual, the modem might need 5min to 30min to sync again with your ISP.
Just rebooted the modem
Well if everything set to the default, log onto http://192.168.100.1/index.asp
the default user Id: admin
password: motorola
Top Arris Computers & Internet Experts
Jesse Walters
Jesse Walters
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
