20 Most Recent ASUS WIRELESS ROUTER |WL-520G - RT (WL520G) Questions & Answers
if you can not remember the password than the ownly thing you can do is a reset (according to manual) than you will be able to log in using default user and password (YOU WILL LOOSE ALL SETTINGS) so you will have to re configure the router...
Have fun!
ASUS WIRELESS... | Answered on Oct 02, 2019
In order to access the web interface of the router you should know the IP address of the router. Please try the following steps to check the ip address on the computer which is connected with the router (wired/wireless doesn’t matter).
1. Click on start the go to run and try cmd and click on ok.
2. Type ipconfig and press enter.
3. look for the default gateway numbers.
the default gateway is the address of the router. Open internet explorer and type http://default gateway numbers (for example http://192.168.1.1)
It should take you to the web interface of the router on which authentication is needed. The default user name and password is admin and admin.
Let me know if it help.
Rashish
ASUS WIRELESS... | Answered on Sep 30, 2019
what kind of connection do you have? and to what? I assume you have an ADSL(high speed) connection to the internet, and are trying to connect wireless to a laptop or something. what kind of devices are you trying to connect together? this will help with an answer.
ASUS WIRELESS... | Answered on Aug 21, 2019
i want to change my asus wireless router password
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure that your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
ASUS WIRELESS... | Answered on Aug 18, 2018
it should be written on the router label or back of router and you can also find it by running the setup utility of the router
ASUS WIRELESS... | Answered on Oct 11, 2017
You might need to go into the setup on your router and be sure it is set to automatically give IP addresses to new devices.
ASUS WIRELESS... | Answered on Oct 02, 2017
I had same problem with my asus device. so i called Asus Tech Support At Toll Free Number 1800-585-2494 and they have fixed my problem.
Hope they will help you as well.
ASUS WIRELESS... | Answered on May 09, 2017
You should call on 1-800-585-2494 Toll Free Asus and get help for Asus.
HTR -3066 not powerin on solution
ASUS WIRELESS... | Answered on Apr 27, 2017
There should be a button on the bottom of the router labeled 'reset'
push it in and the router will reset to factory settings.
( dhcp is usually enabled by default)
the lights for network activity should blink for a few seconds as the
router gets a new ip from the network. you should then
be able to go to 192.168.1.1
and access the router.
some motorola routers use an address in the 10.x.x.x
range
ASUS WIRELESS... | Answered on Jan 06, 2017
Log in to your router's configuration page on the internet. Under the System tab there will be the option to change your password.
ASUS WIRELESS... | Answered on Jan 03, 2017
You should call on 1-800-585-2494 Toll Free Asus and get your help for Laptops.
ASUS WIRELESS... | Answered on Nov 02, 2016
You should call on 1-800-585-2494 Toll Free Asus and get your help for Laptop.
The cd is useful only when you want to install the drivers for using the router through USB port. In your and in most of the cases all you have to do, after the connections, is to start any browser (mozilla, internet explorer, safari e.t.c.), go at the router's page and make all the necessary settings with the web interface. In your router the default router's page is http://192.168.1.1 the user-name is admin and the password is admin.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
ASUS WIRELESS... | Answered on Apr 02, 2015
Try using http://192.168.0.1 to get to the log in page of your router. The username should be: admin and password is either: admin or (no password). If this does not work, there is a reset button located on the back of your router, press this button and hold it for about 10 seconds while the unit is on, then try going to that address again.
If this still does not work, look on the bottom of your router or on the box which your router came in or the manual that came with the router. Check that you are trying to go to the correct IP Address. It should be located on the router itself, although, the standard IP Address for most routers is 192.168.0.1
Thank you for using FixYa! Have a nice day and please remember to rate this solution.
Warm regards,
BearWeb
hi buddy!
first you configure the router to the modem ok
by typing the 192.168.1.1 and follow the instruction ok
PS:
pls rate me if my solution solve the issue and you need more further information. but if is invaluable solution rate me fixya.
Computers & Internet Logo
Popular Tags
130 questions posted
Popular Products
Top ASUS Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Roy May
Marvin
Marvin
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • ASUS Computers & Internet
Most Popular Question
reset asus rt n10e routr
  • Computers & Internet
